RV.Net Open Roads Forum: Tech Issues: Lithium Batteries
 > Lithium Batteries
Page of 13
Itinerant1
Itinerant
Posted: 09/15/20 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
pnichols wrote:
Itinerant1 wrote:
pnichols wrote:
FWC wrote:
pnichols wrote:
Well ... reading this clip below from the Azimuth Solar Products Si02 webpage
https://azimuthsolarproducts.com/product/12v-108ah-ultra-long-life-battery/ under the "Additional Information" tab:
Battery Type
SiO2 Composite Electrolyte Battery
Nominal Capacity (25°C/77°F)
108 Ah (1296 Wh) @ 20 Hour
Nominal Voltage
12V
Max Charge Current
27A
Max Charge Voltage
14.7V
Internal Resistance (25°C/77°F)
=< 6 m?
Max Discharge Current (25°C/77°F)
800A(5S)
Depth of Discharge
100% DOD
Operational Temperature
-40?C to 65?C (-40?F to 149?F)
Self Discharge
< 1.6% per Month
Life Cycle
3400 Cycles at 40% DOD; 1500 Cycles at 80% DOD; 620 Cycles at 100%
DOD
Dimensions
17.2 x 33 x 22 cm (6.77 x 13 x 8.66")
Weight
31.5 kg (69.4 lbs)
Manufacturer
Soneil International Ltd.
Warranty
2 Years Workmanship
It sure looks to me like their SiO2 batteries function in a far, far superior way as compared to good old regular lead acid (liquid or AGM) batteries. Crystals are not the same as liquid or liquid absorbed into mats.
Note that the SiO2 batteries can even be discharged to "zero" about 620 times - which I would never think of doing even once, with any battery in my RV - no matter what the chemistry. (Excluding a capacitor battery of course!)
BTW, that maximum charge current of 27A is perfect for us folks with only 130 alternators when underway, and for us drycamping RV folks with only stock converters and very small portable generators.
The spec actually says discharged to 100% DOD (ie pull the full rated capacity out of the battery), not to zero (volts). As I pointed out this claim is not really substantially different from what deep cycle flooded battery manufacturers claim (see the graph I posted earlier with ~500 cycles to 100% DOD). I am not sure I believe either of these claims, just pointing out that the claims are about the same.
Also note that Gell Cells have a sulfuric acid electrolyte solidified with SiO2 (silica), the difference is that these appear to have more SiO2, but the concept is the same.
What spec do you think is far, far better?
Note that I did not say zero with the word "volts" after it. I of course meant zero state of charge.
SiO2 cycle life - as seen in the SOC graphs for it - sure seems quite superior to that of my current high-end deep cycle AGM batteries. Combined with SiO2 cold weather performance and their price - I'm wondering why continue with AGM when mine wear out, or mess with lithiums and their price for only part-time camping use.
That sums it up pretty well, as a part time camper the dropin lfp cost doesn't offset the benefits for your needs.
BTW, regarding drop-in size RV lithium batteries, take a look inside them to see all the inter-connections inside that gotta stay solid and corrosion-free year of year and vibration after vibration. The number of connections decreases reliability in any piece of electrical equipment or circuit. When are drop-in size lithium RV batteries going to have only three or six large cells?
Most dropins are sealed batteries and you have to go out of your way to open one up which probably void any warranty it had.
Connection, corrosion and vibrations could be a consideration but I think that's stretching it to worry about or why stop there, vehicles and rvs with electronic and computer components are in the same conditions and even more exposed.
Nominal voltage of the cells are 3.2v which is why they are built 4 series combination for 12.8v nominal, 3 or 6 cells doesn't work out so well for voltage.
Here's how at least one model of 100AH vehicle drop-in LiFePo4 lithium battery is constructed:
https://www.lithiumion-batteries.com/upl........2V%20100AH%20Internal%20Design%20PDF.pdf
That sure looks like a lot of "little batteries" hooked up together with a lot of inter-connections that may/can eventually fail. I don't know if Battle Born LiFePo4 lithium batteries are also built of a bunch of small cells - but I bet they are. We're not talking about printed circuit board or integrated solid state electronics here - but a bunch of physical cylinders that have to be kept in place with secure connections between them year after year. Plus how many of those little individual lithium cells have to fail before the entire battery can no longer function properly?
Four (4) larger 3.2V 100AH LiFePo4 cells in series would make a 12.8V 100AH LiFePo4 battery ... with a lot less inter-connections - very similar in construction and fully charged voltage to good old vibration proof AGM batteries.
However, I'm betting that the technology of LiFePo4 battery cells is such that a large pancake type design - like the plates in lead acid based batteries - is difficult or impossible or unsafe to produce for use in a commercial drop-in vehicle sized lithium based battery. Hence drop-in LiFePo4 vehicle batteries must be made up of a bunch of "kludged together" small cells.
So how many failures of said battery design have there been? Or is this one of those debates where you throw enough **** against a wall something is bound to stick?
I don't know my 4s5p setup is pretty easy and straightforward even with all that scary electronics on them.
I wouldn't even call that pdf image you posted a "kludged together" but like 3tons said I'm not looking for the boogie man.
12v 500ah (5,120Wh usable) , 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts) 2s4p. Panels mounted flat on the roof. Magnum PT100 controller, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365
MrWizard
Traveling
Posted: 09/15/20 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
This is a perfect example of large cells
(4) 100 ampHr 3.2v cells make (1) 100 amp HR battery
(5) batteries in parallel make a 500 amp HR battery
Just like stringing (5) 6 cell 12v batteries in parallel
The difference, everything is in one Box/Container
The connections are all inside box,
With lead acid cell connections are in the box and battery to battery is outside cabling
Some of these arguments are nitpicking , trying to turn mole Hills into mountains
Radiate The Happy
1997 F53 Bounder 36s
Bert the Welder
Van. Island
Posted: 09/15/20 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
With regards to vibrations, etc. effecting the connections of all those smaller batt's making up the larger box in that rendering in the posted link (which was neat to see. Thanks) I wonder if missing from the rendering is any type of potting? Yes, filling the box full of epoxy would nix any type of servicing. But one still wonders.
Or one of you smart fella's may already know the answer to this....
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
MrWizard
Traveling
Posted: 09/15/20 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
The cheapie Chinese drop ins
Pot the inside perhaps to keep the smaller cells they use from rattling around
Will Prowse on YouTube has opened several different drop in 12v LiFePo batteries to show the quality or lack of quality
One had been filled with glue after assembly
He also did capacity tests on each one
And he has an interview with Battle Born
AFAIK The good quality ones are not potted
pianotuna
Regina, SK, Canada
Posted: 09/15/20 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
Bert the Welder,
Potting would not work well as the cells need to be cooled.
* This post was edited 09/15/20 10:34pm by pianotuna *
Regards, Don
3 tons
NV.
Posted: 09/15/20 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Now entering the FDZ (fascinating discourse zone), I’ve just donned my tin-foil hat - lol
3 tons
Stanfordstander
Penang Malaysia East
Posted: 09/15/20 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
msmith1199 wrote:
Just downsized from a Class A DP to a Class B+. I got the residential fridge in the new motorhome so power when off the grid is going to be more of an issue that it was before. I’ve been looking at Lithium batteries and they look like a good solution for me. Only problem I see is physical size. The two current batteries I have are 11.5 inches long and they are a tight fit in the battery compartment. All the lithium batteries I’ve seen are at least 12.5” or longer. So they won’t fit in the existing battery compartment without modifications. But those are all 100AH batteries. I see they also have 200AH lithium batteries. They are a lot longer, over 20 inches, but one of those batteries will fit in the compartment versus two 200AH batteries. So not only does the 200AH battery have a smaller footprint than two 100AH batteries, they are also quite a bit cheaper than buying two 100Ah batteries.
Anybody see any issues in going with one 200ah battery versus two 100ah batteries?
My batteries once melted a hole in my pants pocket
pianotuna
Regina, SK, Canada
Posted: 09/15/20 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
Joins 3 tons in my Mylar suit, complete with a chain to drag on the ground a la Marley's Ghost.
pianotuna
Regina, SK, Canada
Posted: 09/15/20 10:38pm Link  |  Quote  |  Print  |  Notify Moderator
It is preferable to have one 200 amp-hour vs two 100 amp-hour jars. It might cost more to do so.
nightshift
Vancouver, BC
Posted: 09/16/20 01:05am Link  |  Quote  |  Print  |  Notify Moderator
Or you could just do this.
Page of 13
 > Lithium Batteries
