RV.Net Open Roads Forum: Tow Vehicles: Should I consider an onboard air pump??
Search only in Tow Vehicles
 > Should I consider an onboard air pump??
renojack
Reno
Posted: 09/05/20 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
I am considering a FW with a pin weight of 2000 lbs.
My vehicle is a 2016 Ram 2500 diesel with a rear axle of 6500 gawr. I plan on installing firestone air ride bags.
My question is how practical is the extra expense for blue tooth controlled pump when the use is seasonal and not daily movement??.
RENOJACK
"The journey IS the destination"
2014 Denali 287RE TT
NV Plate "THETRLR"
2016 Ram 2500 Laramie Cummins 6.7
NV Plate "THE RAM"
Equalizer 1400#
C Schomer
Pueblo West, Co.
Posted: 09/05/20 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
I put onboard air, with a tank and mechanical controls, on my trucks for bags, shocks and the ebrakes. I put a schrader on the back of this truck and I made a hose so I can air up my bike tires. I love it! Craig
time2roll
Posted: 09/05/20 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
I would see how it goes. Add the air if needed.
675w Solar pictures back up
rhagfo
Portland, OR
Posted: 09/05/20 11:55pm Link  |  Quote  |  Print  |  Notify Moderator
First of all you might try the 5er without the bags and save the cost. The coils on the 2500 are pretty good at supporting weight.
As to the on board air I would look at a Viair unit, I have one that provides 150 psi and a 2.5 gallon tank, it will operate my impact wrench. This is a 12 volt unit.
Dave H M
IL
Posted: 09/06/20 01:27am Link  |  Quote  |  Print  |  Notify Moderator
I think time2roll has the answer.
BTW, I use one of the elcheapo 12V air pumps that plugs into the 12V outlet in the truck. Air them up on hook up and you are good to go.
valhalla360
No paticular place.
Posted: 09/06/20 05:58am Link  |  Quote  |  Print  |  Notify Moderator
Agreed.
Unless you have other needs, pumping up the airbags doesn't take much. A cheap 12v or even a bike pump will air them up very quickly.
Now if you take the truck off roading and regularly air down the tires, it starts to make sense to have a built in high capacity system as that takes a lot more air.
We do have a small 120v compressor (non-installed) in the 5er underbelly to air up tires and run an impact gun.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
wanderingbob
monticeeo, fla
Posted: 09/06/20 07:12am Link  |  Quote  |  Print  |  Notify Moderator
A bike hand pump will do easy . I have the same truck with bags and can get them up to 50 lbs in seconds . Onboard air is not for REAL MEN !
Camping near Sandberg, CA
Posted: 09/06/20 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Need to be very careful using a high powered air pump on air bags. I use my bicycle pump. For tires, a portable, Ryobi battery operated pump works great. Ryobi battery also powers my saw, impact drill. Recharges via 110 outlet in truck when driving.
deltabravo
Spokane, WA
Posted: 09/06/20 07:41am Link  |  Quote  |  Print  |  Notify Moderator
I haven't seen or heard of a Bluetooth system
I run the Airlift Wireless controller and compressor. It's been flawless for the 10 years I've used it. I would never want to deal with manually inflating the airbags. I can change pressure on the fly.
Get a wireless system and go camping!
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
Turtle n Peeps
California
Posted: 09/06/20 09:23am Link  |  Quote  |  Print  |  Notify Moderator
I have a blue tooth compressor system and I would not do with out it. Had it for 2 years or so. I use it a lot. I can adjust it with my phone or my fob.
Blue tooth gives me the option to adjust to road conditions on the fly.
If you live where they put salt down I would protect the compressor as much as I could from it.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
