RV.Net Open Roads Forum: Looking for Transmission cooler radiator 03 Diplomat
 > Looking for Transmission cooler radiator 03 Diplomat
jimj
Southern IN
Posted: 09/06/20 08:08am Link  |  Quote  |  Print  |  Notify Moderator
I have developed a leak in the tank on the tranny cooler. I have had it welded twice so that isn't working very good. It is getting a crack in the tank in the same place and the weld isn't holding. I don't see any stress on it in that area but maybe the vibration is breaking it.
If anyone knows of a source for the older Monaco parts please let me know.
The radiator is 12" x 22" Aluminum and mounts on top and r side
I could try another weld job but would like to replace it.
Thanks for any help
JimJ 2003 Diplomat
MountainAir05
New Mexico
Posted: 09/06/20 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Source Engineering inc. Coburg, Or. rv-chassis.com 541.935.0308
OEM supplier for radiators and CAC's
Phillip Cochran C,G & J Inc Heat Transfer
Brice Thomas Radiator
256-546-4613 work
256-312-2828 cell
www.cgj.com
https://radiatorsupplyhouse.com/
* This post was edited 09/06/20 09:16am by MountainAir05 *
jimj
Southern IN
Posted: 09/06/20 08:42am Link  |  Quote  |  Print  |  Notify Moderator
O sorry I thought I made that clear it is a separate radiator for the tranny. It is 12"x22". I am looking for a replacement.
Thanks
JimJ
enblethen
Moses Lake, WA
Posted: 09/06/20 09:03am Link  |  Quote  |  Print  |  Notify Moderator
You could try Colaw.
They have many salvaged MHs.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
K Charles
Connecticut
Posted: 09/06/20 10:25am Link  |  Quote  |  Print  |  Notify Moderator
256-546-4613 work
256-312-2828 cell
www.cgj.com
You may never get a better answer then this.
rgatijnet1
Posted: 09/06/20 10:37am Link  |  Quote  |  Print  |  Notify Moderator
None of the RV manufacturers made their own oil coolers. They all use standard sizes that are available. I'll bet that any radiator shop could find a replacement based on the size and the number of rows of cooling lines.
jorbill2or
Full time
Posted: 09/06/20 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
Source is a good choice but if you take the measurements to a Radiator shop in your area they can match it or order it built.
Bill
TANDDANDBIGE
W. Wa. State
Posted: 09/07/20 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Radiator Supply House in Sweet Home Oregon can make any size and type of cooler.
2002 HR ENDEAVOR 40'
2007 FORD EDGE TOAD
wolfe10
Posted: 09/07/20 10:50am Link  |  Quote  |  Print  |  Notify Moderator
Hayden has a number of different size coolers.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
jimj
Southern IN
Posted: 09/26/20 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Just a followup on the transmission cooler radiator leak. The tank developed a leak for the second time, first time was 2 years before, I removed it and had it tig welded at a machine shop and it looked good but it developed another leak after around 400 miles so filled up with tranny fluid @$52/gal and limped to my destination. Took it off again, getting pretty good at this, took it to a machine shop and explained where it was splitting and that I wanted a patch welded over the corner where it was leaking. They Tig welded the crack then welded a patch over it. I think it will hold only time will tell.
Thanks for all the helpful replies but I was forced to get it done quick so the patch job.
Thanks
JimJ
