RV.Net Open Roads Forum: Truck Campers: Propane gennie maintenance in cold winter
 > Propane gennie maintenance in cold winter
Slymer
Ontario, Canada
Posted: 09/06/20 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Outdoor Canadian winter storage.
Take both batteries out, but now I have to run the propane gennie for an hour each month. Do I have to put a battery back in, or use a battery booster pack,.....OR,.....can I just plug it in to 110 volt and bypass the batteries to get the gennie started ??? Putting a battery back in/out monthly would be a pain.
2013 Arctic Fox 811S.
I didn't run it at all last winter and spent HOURS & HOURS this spring/summer getting it started again.
bgum
South Louisiana
Posted: 09/06/20 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
A propane gen should not gum up like a gas genny. Do you also run it on gas? If so run the gas out and drain the carb then run some seafoam in it. Put a small amount of light oil in the cylinder. And turn the engine over by slowly pulling crank.
Slymer
Ontario, Canada
Posted: 09/06/20 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
Strictly propane. It was stock on the 2013 AF 811's. Cummins/Onan.
jimh425
Western MT
Posted: 09/06/20 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
I’m not sure why it would take you hours and hours to get your generator back going or why you need to run your generator during the Winter an hour each month. What was wrong, or what did you do to fix it?
You should be able to prime the generator and as long the battery is good, you shouldn’t have an issue getting it back running. One other hint to to ensure the propane lines are full by running other items like the stove.
I’ve had the case that the propane fuel had either water or too much additive in it. That caused my generator to sputter.
bgum
South Louisiana
Posted: 09/06/20 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Fire and fuel
After the cold is past make sure you have a spark at the plug then light your propane stove to make sure your regulator is working and lastly with strong battery try to start the genny.
jdc1
Rescue, Ca
Posted: 09/06/20 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
You don't need to do anything to the propane generator during the winter or any other time it sits for long periods.
midnightsadie
ohio
Posted: 09/06/20 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
I live in ohio I start my pp in nov and again in april never had a problem.
deltabravo
Spokane, WA
Posted: 09/06/20 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
A booster pack should work to get it started.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
noteven
Turtle Island
Posted: 09/07/20 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Slymer - if a propane engine will not start even after sitting for weeks something is amiss.
Our propane fueled motor vehicles back in the day had vacuum actuated and electrically actuated fuel shut off valves to stop the flow of fuel if the engine stopped turning or ignition power was disconnected - not sure if generators have such safety devices?
Slymer
Ontario, Canada
Posted: 09/08/20 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Most of my hours & hours were spent on Google, and trying the possible fixes I found there. I have it going now (unknown why), but the manual clearly states run monthly, under half load, for 45 minutes. The booster pack will be much easier than re-installing the batteries. Thanks folks.
