RV.Net Open Roads Forum: water has air come out every time used
 > water has air come out every time used
TomandCandy
Olympia, WA
Posted: 09/06/20 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Ok its normal for air to come out after draining rv and filling up with water my brother- in -law has a 5 wheel and every time you turn on the water air comes out. the pump does not kick on when sitting no water leaks I have never had this happen to me any ideas I don't have a clue thanks Tom
coolmom42
Middle Tennessee
Posted: 09/06/20 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Somewhere there may be a high point in the system that has air in it... possibly a shower head. Find it and run all the air out.
Also the fresh water tank can get air trapped in it by sloshing around during towing.... but not that much.
Possibly the uptake side of the water pump (if it's in use) has an air leak and is sucking air in along with the water.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
Old-Biscuit
Verde Valley
Posted: 09/06/20 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
Same issue using city water or pump?
If pump only......suction side of pump is sucking air in
kedanie
Albuquerque, NM
Posted: 09/07/20 09:26am Link  |  Quote  |  Print  |  Notify Moderator
There is usually a strainer just before the pump. It has a plastic bowl that unscrews to clean out. If it is not emptied when winterizing, it will freeze and crack. The pump will suck in air through the crack.
Keith
Keith and Gloria
2013 Tiffin Phaeton 36GH
2012 Jeep Grand Cherokee Overland
USAF 1968-1976 Vietnam Veteran
doxiemom11
Paris Michigan
Posted: 09/07/20 10:17am Link  |  Quote  |  Print  |  Notify Moderator
We have had that , our water filter was not positioned just right. Unfasten and reinstall.
Seon
Lake Camanche, CA
Posted: 09/07/20 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Just happened to my new to me TT during our maiden voyage. Couldn't figure out why wate/air kept spurting out. Got home and decided to put more water in the tank....problem solved [emoticon] .
