RV.Net Open Roads Forum: I'm installing rigid insulation on the underbody.....
 > I'm installing rigid insulation on the underbody.....
BackOfThePack
Fort Worth
Posted: 09/11/20 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Skirting is a better choice. Heavy-vinyl (snap). Blocking air movement is that which “insulates”.
Otherwise, avoiding moisture collection (accelerating rust & rot) is a genuine problem to solve when installing underfloor insulation
2004 555 CTD QC LB NV-5600
1990 35’ Silver Streak
dpglifestyle
michigan
Posted: 09/12/20 04:08am Link  |  Quote  |  Print  |  Notify Moderator
As far as the bulge from the tank you can run a steel strap from frame rail to frame rail under the tank. Install with an empty tank, pull tight and screw to the frame. A lot of units come this way.
2015 Lifestyle LS36FW
2016 GMC 3500 CC Dually
agesilaus
North Florida
Posted: 09/12/20 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Exactly what I was thinking, use plumbers strapping aka hanger strap
Amazon
Get it at any hardware store.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Minerrick
Truckee, CA
Posted: 09/12/20 08:22am Link  |  Quote  |  Print  |  Notify Moderator
I was thinking the same thing.... thanks for the tip.
campigloo
Baton Rouge, La
Posted: 09/12/20 08:57am Link  |  Quote  |  Print  |  Notify Moderator
When I got my panels they recommended well nuts. I couldn’t find any locally. I used hollow wall anchors and they’ve worked good. The sheeting on mine is 3/8 chip board. Call the manufacturer and they will probably tell you what’s up there. Three years and ~40k miles and there still very solid.
Blazing Zippers
North Idaho
Posted: 09/13/20 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
minerick, a dealer installed three steel angle beams from one frame rail to the other to stop tank sag. They were screwed in the frame and were under the coreplast. This was on warrantee. I can't comment on the repair, because 75 miles later an axle locked up and we crashed the entire rig. It was an Arctic Fox 25R brand new. YeeHaw!
As a former resident of Truckee, I know how cold it gets. Are you trying to insulate the camper for winter usage or do you intend to tow it after the mods? If you're intending to park it for winter, you might consider the moisture element also. Propane heaters and stoves put out lots of dampness.
JoeH
Apollo Beach,FL
Posted: 09/14/20 07:24am Link  |  Quote  |  Print  |  Notify Moderator
I would put a strip of old inner tube rubber or similar material to cushion the plastic tank from the steel.
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
Minerrick
Truckee, CA
Posted: 09/15/20 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
Nah, we live in a home in Truckee, so we have no intentions of trying to live a winter in it (Brrrrrrr). We use it typically for early and late fall camping, and oftentimes we get caught in snowstorms and cold weather, so we just want to try to keep it a bit warmer.
