RV.Net Open Roads Forum: Travel Trailers: Fed up with tire blow outs!!!
 > Fed up with tire blow outs!!!
Page of 9
dodge guy
Bartlett IL
Posted: 09/09/20 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
rollindowntheroad wrote:
I talked with a tire dealer this morning, locally, they told me that Goodyear makes an Endurance in 215/75r14. They didn't have any in stock but could order them and get them in a couple of days. The only difference is that the 215's are a little wider than the 205's. I measured my TT and the 215's will fit. I ordered them. Total was $602.00, that's everything even put on my TT. Then the guy says they will probably be delivered on Friday. We are having a sale this weekend that anyone that buys a set of 4 tires gets $100 off. So your total will be $502.00. YIPPEE!!! Made my day!
So Goodyear Endurance 215/75r14 is what is going to be put on. Hopefully no more blowouts!
What load rating?
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
time2roll
Posted: 09/09/20 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
I thought you could find some GY Endurance if you kept at it.
Most people just want to sell what is on the shelf.
Great tires so far.
675w Solar pictures back up
2112
Posted: 09/09/20 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Congratulations on your purchase. Money well spent.
Below is the inflation chart for your new tires.
2013 KZ Durango 2857
Posted: 09/09/20 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
That's a great deal!
LarryJM
NoVa
Posted: 09/09/20 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
dodge guy wrote:
All 3 tires did not blow at the same time. The first to go was the driver side rear. This weekend the passenger side rear blew on my way to the campground. On my way home the passenger side front went. Each time I heard the tire pop I pulled over immediately.
Yep, and when the drivers rear went out, you immediately overloaded the other three tires. Repeat for the other two losses -- the remaining tire on that side
Doesn't matter how quickly you reacted -- they still had to carry extra weight, and suddenly at speed.
Unless they are torsion axles not true. A standard trailer with an equalizer between the springs distributes the weight between the axles evenly, that's why it's called an equalizer.
However, the range of the equalizer function IMO won't compensate for for the loss of a tire nor is it designed to do so.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
dodge guy
Bartlett IL
Posted: 09/10/20 05:52am Link  |  Quote  |  Print  |  Notify Moderator
Larry
The distance the axle can move is quite a bit more than height of the sidewall of a tire.
Jebby14
Windsor Ontario
Posted: 09/10/20 10:16am Link  |  Quote  |  Print  |  Notify Moderator
time for LTs
Q: Whats brown and sticky???
A: A Stick....
LarryJM
NoVa
Posted: 09/10/20 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
Larry
Again my previous statement clearly has the caveat IMO in it since I'm no expert and I don't see how that small "equalizer triangle that connects to two axles springs together would allow that much movement to ensure that each ground contact have equal weights on them. I just know I sure would not assume to be the case and I would still replace tires in pairs because of the excessive overloading should you loose one tire on a side of a tandem axle trailer.
Larry
Posted: 09/10/20 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
^ And to that, I would not just replace a tire because it was "overloaded" for say 30 seconds while getting pulled off the road after a blow out.
Different story if the blowout isn't noticed and the trailer runs some distance on 1 tire.
JRscooby
Indepmo
Posted: 09/11/20 04:37am Link  |  Quote  |  Print  |  Notify Moderator
On a vehicle you are riding in, I can see lower pressure for smooth ride. For a trailer, put them to max.
Page of 9
