RV.Net Open Roads Forum: Tech Issues: Replacing ceiling lights & adding more light
 > Replacing ceiling lights & adding more light
coolmom42
Middle Tennessee
Posted: 09/08/20 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
As usual, the incandescent bulbs in my ceiling lights put out way too much heat, use way too much electricity, and don't put out enough light. Also the fixture covers are somewhat dingy.
I'm looking at these Lumitronics brand for both double and single light fixture replacements. Color temp is listed as 2833K, which is good. Lumen output is listed as 455, which is less than a 60 W incandescent, but as many fixtures as I have, that should be enough. I like that the cover is overall diffused so there is not a blinding bright spot in the center.
In spite of having a lot of ceiling lights, there is not a switch by the door for any light. Also some black holes in basement storage and a couple of cabinets. I'm thinking about getting a few of these battery powered lights to stick around in such locations. They have good reviews on Amazon and on Harbor Freight. (cheaper on Amazon.)
Just wondering if anyone has used these specific fixtures???? or have something possibly better to suggest?
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
pianotuna
Regina, SK, Canada
Posted: 09/08/20 11:57pm Link  |  Quote  |  Print  |  Notify Moderator
coolmom,
Jump to LED bulbs. Not much heat, not much electricity, and up to 5 times the lumens. No need to change the fixtures--just buy bulbs. I only bought leds for my most commonly used lights.
For your door, try a motion detector solar powered light for outside. For inside use the same technology--but battery powered.
I got two of the "switched" lights you linked to at a dollar store--for about a dollar. The adhesive on the back is less than special. Mine fell off in less than a week. But that's easily fixed.
Regards, Don
MrWizard
Traveling
Posted: 09/09/20 03:00am Link  |  Quote  |  Print  |  Notify Moderator
I changed all the ceiling fixtures in this RV to new led fixtures kohree brand from Amazon
You will love the power savings
But first I tried led replacement lamps (corn cob bayonet bulbs) in the old fixtures,
But between the old yellowed defusers and corn cob design lamps just not enough light output
The new fixtures with flat board lamps
Give much more light, and measured as using less power
Radiate The Happy
1997 F53 Bounder 36s
BarabooBob
Baraboo, WI
Posted: 09/09/20 03:12am Link  |  Quote  |  Print  |  Notify Moderator
I have replaced all of the lights in my last 2 RV's with LED's. My current TT came with all LED lights but I added a couple more. I will never go back to incandescent bulbs. The current TT also has LED marker and tail lights. I prefer the brighter (almost blue tinted) light temp.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
Sjm9911
New Jersey
Posted: 09/09/20 05:38am Link  |  Quote  |  Print  |  Notify Moderator
I replaced the bulbs. In my TT they went nuts with the light fixtures. Lol. The leds will give you a ton more light.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
madjack60
littleton
Posted: 09/09/20 06:07am Link  |  Quote  |  Print  |  Notify Moderator
The bulbs in mine were 1141 bulbs and I replaced 20 of them for about $24 with LED bulbs from amazon.
2001 Itasca 31c
2oldman
Mecca
Posted: 09/09/20 09:27am Link  |  Quote  |  Print  |  Notify Moderator
I had one of those. The switch failed in just a few months. 2800k is a bit on the yellow side.
JimK-NY
NY
Posted: 09/09/20 10:51am Link  |  Quote  |  Print  |  Notify Moderator
When I bought my camper 10 years ago I immediately replaced all the bulbs with LED bulbs. They were expensive at the time but worth it. A few years ago I got tired of the old fixtures and poorly designed switches. The new fixtures are really inexpensive and the switches and light is much better.
At this point it is hard to go wrong with LEDs. Just be sure they are rated for up to about 15 volts because absorption charging will be somewhere around 14.4 volts.
You might also want to reconsider the temperature rating for your LED lights. 3000K sounds good because it matches what most of us were used to years ago with incandescent lights. They emitted very yellow light. I have switched to 5000K lighting. I like the fact that the lighting is closer to sunlight. Now 3000K lighting just seems dingy.
ndrorder
Southwest
Posted: 09/09/20 11:21am Link  |  Quote  |  Print  |  Notify Moderator
I've been very happy with these LED incandescent replacements. 2 years and no failures.
https://smile.amazon.com/gp/product/B017386GLS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
__________________________________________________
Cliff
2011 Four Winds Chateau 23U
toddbailey
Seattle Wa
Posted: 09/09/20 11:30am Link  |  Quote  |  Print  |  Notify Moderator
In my case, most of the ceiling lights were thin lite dual 18" fluorescent. These are ok when new but after many years flicker and fail, and burn though new bulbs fairly quickly. I finally decided to remove the ballasts and sockets and lay down a strip of led lights. nice thing is you can not only choose the light temp but the lumen output. I went with 3500K is is a nice color, for the living room and hallways, in the dinning kitchen area I went a tad bit warmer and used 3000K. what few incandescent were also upgraded to leds (1141 series) with 2700 K 300 lumen , I got the leds from superbrightleds.com and the 1141 drop in off amazon. All told a bit spendy but much better to just have lights that don't flicker and need to be managed all the time to get them to work.
