RV.Net Open Roads Forum: General RVing Issues: External shower ==> Garden Hose
 > External shower ==> Garden Hose
K3WE
Missouri
Posted: 09/09/20 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Apologies for an uber-lazy post; however, I can't quite picture the part I need.
I'd like to remove the shower head, and screw in something that would convert to a male garden hose fitting...
Just not quite sure what magical part will "imitate" the shower head and have pipe threads on the other end.
Would love to hear a story or two from folks who have done the same.
Thanks.
fj12ryder
Platte City, MO
Posted: 09/09/20 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
It would depend on what you have now, what kind of hose and fittings, shower head, etc. Our Fuzion came with a quick disconnect hose that had the hose fitting already attached.
Howard and Peggy
"Don't Panic"
DrewE
Vermont
Posted: 09/09/20 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Usually shower heads (both handheld and wall mount) have 1/2" NPT threads. You probably need a 1/2" NPT to garden hose adapter, which should be available at a home center, plumbing supply place, etc. At worst, you may have to combine a couple of fittings/adapters.
Wall-mount shower heads have female threads; handheld units have male threads, and the hose between them and the wall has female threads at either end. These are the standard attachments; I suppose it's possible your RV is different, but that would be somewhat unexpected.
K3WE
Missouri
Posted: 09/09/20 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you! I was too chicken (and lazy) to believe it was just 0.5”
NPT...but now that I think about it...duh & LOL.
That’s my one stupid lazy question for the year! :-)
rexlion
Broken Arrow OK
Posted: 09/09/20 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
If you're that lazy about it, forget the connectors; just use duct tape! [emoticon]
Mike G.
--for now, using a cargo trailer for camping--
Those who would give up essential liberty, to purchase a little temporary safety, deserve neither liberty nor safety. --Benjamin Franklin
photo: Yosemite Valley view from Taft Point
Wherever I happen to park
Posted: 09/09/20 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks.
Very popular item
Shower head is 1/2 Inch NPT Most any hardware will have one
NOTE: the Shower HOSE may not properly screw into it and seat since it seats with a washer.. If that is the case I'll fix you up.
THe two items below are male and female on the pipe side
https://images.homedepot-static.com/productImages/924651bd-fa5b-4fff-bc55-0e5f90cb68fb/svn/brass-everbilt-brass-fittings-801799-64_1000.jpg
https://www.grainger.com/product/4KG83?gclid=Cj0KCQjw-uH6BRDQARIsAI3I-UeiOaEuTshd7WFs_wHFENB5LS3rlWa-jXCL7BPwF5c5Kx2jnH9QhNkaAkuYEALw_wcB&cm_mmc=PPC:+Google+PLA&ef_id=Cj0KCQjw-uH6BRDQARIsAI3I-UeiOaEuTshd7WFs_wHFENB5LS3rlWa-jXCL7BPwF5c5Kx2jnH9QhNkaAkuYEALw_wcB:G[emoticon]&s_kwcid=AL!2966!3!264955916294!!!g!438970240505!&gucid=N:N[emoticon]S[emoticon]aid:GGL[emoticon]SM-2295[emoticon]F8O8T:20500731
If hooking to the faucet the female to hose should work
If hooking to the hose try the male to hose and get a short double female (Collar that joins two pipes) you may also need another 1/2 inch rubber washer or 2 to make a good seal.
Home is where I park it.
K3WE
Missouri
Posted: 09/09/20 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Awesome suggestion! Now I can fill my water tank and not have to have hook ups ;-)
Thanks for adding some fun!
Dutch_12078
Winters south, summers north
Posted: 09/09/20 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
I slapped together a quick 1/2" NPT to garden hose adapter using some CPVC parts I had in my spares stock. I mostly use it to feed the black tank flushing wand from the shower hose from time to time.
Dutch
2001 GBM Landau 34' Class A
K3WE
Missouri
Posted: 09/10/20 07:12am Link  |  Quote  |  Print  |  Notify Moderator
^^^***Like***^^^
spoon059
Just north of D.C.
Posted: 09/10/20 07:33am Link  |  Quote  |  Print  |  Notify Moderator
There is a kit that you can swap your outdoor shower head with a similar head with a quick disconnect for a hose fitting.
https://www.amazon.com/dp/B01N3169US/ref=twister_B07RZ7966F?_encoding=UTF8&psc=1
This is an all plastic one, I would probably look for one with brass fittings. I've been toying around with doing something like this. When we go to the beach we all shower off outside first. Our outdoor shower is right above the sewer pipe and the existing short hose doesn't give us much room to clean off.
2015 Ram CTD
2015 Jayco 29QBS
