RV.Net Open Roads Forum: Travel Trailers: first time out
 > first time out
Family-of-five
Cardale Pa
Posted: 09/09/20 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Hello friends This weekend will be out first time out in our new open range light 31bhs. I only have 15 amp to it in the driveway to keep the battery charged and run lights . just wondering what to check for after hooking up to 50 amps. I know to test the water heater on lp and electric.Look for leaks underneath.Test both ac units and furnace.Can you offer some small things I might overlook?
Near Annett’s Mono Village, Bridgeport, CA
Posted: 09/09/20 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
Test the campground 50 amp before plugging in.
MarkTwain
Northern, Ca. , USA
Posted: 09/09/20 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
If you have not packed the wheel bearings in the last year, do so. Carefully check tires for air maximum air pressure, cracks etc. Put about 30 gallons of water in your fresh tank. Make sure battery water is filled up, check for any battery post, cables for corrison.
Sjm9911
New Jersey
Posted: 09/09/20 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
Fill the water heater before turning it on.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Mark and Linda
Smyrna, Tennessee
Posted: 09/09/20 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Have you hooked city water up to it and checked things out, leaks etc before leaving the driveway? If you do that you can check your hot water heater there at home, check the heater etc. Do a good preflight at home before heading out and you should not have any problems.
Posted: 09/09/20 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
If you have not packed the wheel bearings in the last year, do so. Carefully check tires for air maximum air pressure, cracks etc. Make sure battery water is filled up, check for any battery post, cables for corrison.
Reading comprehension my friend...
Posted: 09/09/20 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
You can test pretty much everything above in your driveway off the household circuit, except maybe the AC's. Even those may work with a quality short cord if there isn't anything else pulling on that circuit. Worst case you pop a breaker in the house.
Just test the big stuff 1 at a time at home (H20 heater, AC, microwave).
Filler with water, run all the water stuff, tire pressure, etc at home preferably before you go.
Have fun!
Family-of-five
Cardale Pa
Posted: 09/10/20 03:57am Link  |  Quote  |  Print  |  Notify Moderator
what do you use to test the power?
pbeverly
South Carolina
Posted: 09/10/20 05:21am Link  |  Quote  |  Print  |  Notify Moderator
At the very least with a voltmeter check volts and polarity. Volts are where and what they should be and not where they shouldn't be.
Ridgeway, SC
wanderingbob
monticeeo, fla
Posted: 09/10/20 09:59am Link  |  Quote  |  Print  |  Notify Moderator
You can check every thing in your driveway except maybe the air cond.. Leave some water in your tank when traveling in case you need a potty break on the road . As soon as ya turn water pump on or hook up to water get in the habit of turning on a hot water spigot this will ensure that you have water in water heater .
 > first time out
