RV.Net Open Roads Forum: Travel Trailers: Thought on suspension equalizers
 > Thought on suspension equalizers
sparky853
Ontario, Canada
Posted: 09/10/20 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Wondering if anyone has done an upgrade to their trailer suspension by adding an equalizer, such as a Lippert Equa-Flex Equalizer, and whether it was worth the time and $ to install? Thinking of doing this upgrade and wondering what others experience was like.
WNYBob
Tonawanda, NY
Posted: 09/10/20 06:19am Link  |  Quote  |  Print  |  Notify Moderator
I upgraded my suspension a couple years ago to to E-Zflex and brass wet bolts (OEM plastic bushings were worn through). The difference was amazing!
I don't use sway bars and it cut sway dramatically when trucks passed.
My truck rattles more going over than the TT does going over RR tracks.
azdryheat
Tucson, AZ
Posted: 09/10/20 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
I had Equa Flex. I now have EZ Flex and like it much better.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2016 RZR 900
Huntindog
Phoenix AZ
Posted: 09/10/20 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
It is a huge upgrade. Moryde also makes them.
I won't have a trailer without them anymore.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FBP, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
300 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
ken56
Tennessee
Posted: 09/10/20 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Definitely worth the money to do. It's not a terribly hard job but it is work to do. If you are not experienced at working on vehicles have a local shop do it for you, no need to go to an RV dealer. You need a couple floor jacks and jack stands to stabilize the trailer while you work on it. A ball joint tool is handy to press the new brass bushing in although I used a large C-clamp. It made a huge difference in trailer ride. Quieted things down too.
dodge guy
Bartlett IL
Posted: 09/10/20 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
I did the Dexter EZ Flex on my old TT. I also did the wetbolt kit and bronze bushings while I was at it. best thing I did to it. after I did it the trailer was much more stable (the old bushings and bolts were worn badly). I no longer felt any of the bridge expansion joints. It was also better when rolling through a campground and it no longer squeaked its way through!
Worth every penny!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
BurbMan
Islip, Long Island
Posted: 09/10/20 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Definitely worth the upgrade. If you're going to do it, also invest in the Dexter HD shackle set with either greasable bolts or the the never fail bushings. The shackles that the factory puts on are cheap and the bushings are cheaper.
2015 Ram 3500 4x4 Laramie Crew Cab Long Box, Cummins diesel
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
time2roll
Posted: 09/10/20 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
Dexter on mine.
675w Solar pictures back up
jshupe
FT
Posted: 09/10/20 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
I upgraded from the Lippert Equa-Flex to MORryde SRE4000 with X-factor crossmembers. This trailer always had an equalizer, but the change in models made a huge difference - not all of them are created equal.
2015 Keystone Alpine 3730FB, 2019 Ram 3500 HO/AISIN CCLB DRW, 2020 JLUR
Primarily off-grid living w/ 2925W solar and 22.8kWh LiFePO4, 30K 240V multi-split,
a custom bladder/pump/monitor setup so we can use water as we wish, and more
Vintage465
Prunedale CA.
Posted: 09/11/20 06:33am Link  |  Quote  |  Print  |  Notify Moderator
Yup. All the above. I used MorRyde SRE3000 and hefty shackles with wet bolts too. Also, not to put more dirt over the grave, but consider getting new springs for a couple reasons....your existing ones are prolly Chinese(your new ones will be too) and could be on the minimum rating(mine were 1750's, replaced with 2500's). In reality springs are about a $150.00 investment and you'll have them all removed while installing the new system. One of my springs broke just before I was planning to do the upgrade.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retiring in 2021, then look-out road, here we come!
