RV.Net Open Roads Forum: Fifth-Wheels: Weighing at Cat Scales
 > Weighing at Cat Scales
dryfly
Posted: 09/10/20 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
After watching a couple of youTube videos, apparently the only way to determine the exact pin weight of a 5th wheel trailer is to weigh the truck/trailer and then disconnect the trailer and weigh the truck by itself. The unloaded rear axle weight of the truck compared to the loaded rear axle weight should provide the trailer actual pin weight.
Having never weighed at a Cat Scale, is the procedure to go inside and explain what is needed before driving on the scale platforms? I assume there will be two charges.
dapperdan
Milwaukee
Posted: 09/10/20 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
When I weighed my rig, Loves was "nice" and only changed me for 1 weigh-in even though I weighed once WITH the trailer and once without.
It's fool proof and accurate. Good luck!
Dan
fj12ryder
Platte City, MO
Posted: 09/10/20 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
At the Cat scales here in town, the first weigh is like $8 and the second weigh, done within a short period of time, is $2. Or it was the last time I looked.
Howard and Peggy
"Don't Panic"
azdryheat
Tucson, AZ
Posted: 09/10/20 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Go inside, tell the clerk it's your first time and you'll be taken care of.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2016 RZR 900
Walaby
Georgia
Posted: 09/10/20 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Download the app and you don't even have to go inside. App will properly charge the reduced cost for the re-weigh.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
Old-Biscuit
Verde Valley
Posted: 09/10/20 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
Pull pm to scales with truck and trailer
Truck front axle on forward platform
Truck rear axle on middle platform
Trailer axles on rearward platform
Push call button....tell them 'Private' when they ask for ID number
Clerk will trip scales....
Then drive off scales and go park trailer in parking lot.
Drive truck onto the forward and middle platforms
Push button----'Private' Reweigh
Go park truck, go inside, pay and get your weigh tickets
1st ticket
truck steer, drive axle and trailer axles plus total
2nd ticket
truck steer, drive axle and total
Difference between truck Front and rear axles with trailer and without trailer is trailer pin weight
It's not just rear axle...check for any differences in front axle weights
Depending on hitch placement in truck bed front axle weight could be same, could be less, could be more
My hitch is set 2" forward of rear axle center line and this transfers 150# to front axle when 5vr is hitched plus the weight added to rear axle
So I add the 2 figures to get my pin weight -- 3080# = 22% pin weight on my 5vr
JRscooby
Indepmo
Posted: 09/11/20 04:26am Link  |  Quote  |  Print  |  Notify Moderator
1st ticket
2nd ticket
When pull on for 2nd weigh, stop TV same place as first.
Subtract 2nd gross from first, this will give you the weight of the trailer. The first weight slip will give you the weight on trailer axles. Subtract that from the calculated weight of the trailer will tell you how much weight the truck is carrying.
The button is placed for easy reach by the driver of a class 8 truck. For me to reach it I open door, stand up on door sill while leaning on top of door. My weight is still split between same platforms.
* This post was edited 09/11/20 04:32am by JRscooby *
valhalla360
No paticular place.
Posted: 09/11/20 04:59am Link  |  Quote  |  Print  |  Notify Moderator
As long as it's at the same time, you can go drop the trailer in the yard and do a "re-weigh"
First weigh is around $12.00.
Second weigh is $2.50.
If you are doing a bumper pull with a WDH, it's a good idea to do a 3rd weigh (again $2.50) with the tension released from the bars.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
JRscooby
Indepmo
Posted: 09/11/20 07:03am Link  |  Quote  |  Print  |  Notify Moderator
I have seen this advice many times but have never understood what useful info is gained
Mike134
Elgin
Posted: 09/11/20 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Mike
X2 I've gone inside and used the app. SOOOO much easier/faster with the app.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
