RV.Net Open Roads Forum: No 12v input from battery, 2004 Terry Trailer
 > No 12v input from battery, 2004 Terry Trailer
BEagen
Huntington Station, NY
Posted: 09/11/20 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
I accindentally installed one of my two, 6v batteries backwards, creating a reverse polarity. Since then, the trailer's converter will not recognize 12 volt battery input. I read about the possibility of a separate, resettable breaker that is used to protect the converter in such a situation. I've looked high and low and cannot find one. I have a 2004, Fleetwood Terry 300BH trailer. The fan in the converter runs when plugged into A/C power, but won't recognize the (new) 12 volt house battery. Interesting, the 12v systems work when the trailer is plugged into the the tow vehicle. Any advice greatly appreciated.
2oldman
New Mexico
Posted: 09/11/20 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
I'm a bit confused on how ONE backwards creates reverse polarity. I would think that means you connected them in parallel instead of series, resulting in 6v, which is not recognized.
If you come back, please post a wiring diagram.
* This post was edited 09/11/20 04:01pm by 2oldman *
carringb
Corvallis, OR
Posted: 09/11/20 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
My trailer fuse panel has a reverse polarity protection fuse.
Did you double check you connected the 2 x 6v batts in series?
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
Old-Biscuit
Verde Valley
Posted: 09/11/20 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Converter should have 'reverse polarity' fuses.....depending on amp size of converter One or Two 30A fuses
Depending on converter they could be on DC Dist Fuse Panel or on converter
They blow if battery cables are reversed and then NO 12VDC from battery to DC Fuses
BEagen
Posted: 09/11/20 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman: The two 6v were in series, but one was inadvertently reversed. I assume that created a reverse polarity situation. Sorry, I don't know how to post a diagram.
carringb: Wiring diagram shows a 40 amp fuse between the battery and converter but I can't find it. Believe me, I have looked and looked...
Old-Biscuit: I agree. But, cant find anything like that. No 30 amp fuses on the DC Dist Fuse Panel; just 15s and 20s.
I need to find the in-line fuse/breaker somehow. Thanks for all your comments and insights.
Fisherman
Angus, Ontario, Canada
Posted: 09/11/20 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
If you connected the batteries neg to negative and then connected the other two terminals to the trailer wiring, nothing would happen, power only flows in one direction.
Where the main RED battery wire connects at the rear or front of the DC fuse panel, there has to be a fuse. The fuse boards come that way. Maybe someone stuck a 20 in there.
Boon Docker
Posted: 09/11/20 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Follow the battery cable (likely the negative) from the battery to where it goes under the trailer look for small (approx 1" x 1.5") circuit breaker (box). Should be 2-3 ft from the battery, it may or may not have a reset button.
Old-Biscuit
Verde Valley
Posted: 09/11/20 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Except -----
Fuse will be on POS cable
On the a-frame and will be a small 2 stud box...reset is typically on side of the DC Circuit Breaker
Example: DC Circuit Breaker
Example: Reverse Polarity fuses on DC Dist Fuse Panel----40A
Gdetrailer
PA
Posted: 09/11/20 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Except -----
One should note that the breaker shown in photo IS a "self reseting" or "auto reseting" breaker (IE no reset button to push) and is typical breaker used by RV manufacturers.
HOWEVER, in order to get this breaker to auto reset, one MUST REMOVE BOTH POWER SOURCES (IE converter must be powered down AND the battery source must be disconnected from the circuit). Once all power has been removed from the circuit then and only then will the breaker reset.
Do that first before throwing parts at this.
Boon Docker
Posted: 09/11/20 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Except -----
My circuit breaker is on the negative cable of the battery.
