RV.Net Open Roads Forum: Class A Motorhomes: Tradewinds 2001 model 7390
 > Tradewinds 2001 model 7390
SGTJOE
Utah
Posted: 09/11/20 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
My MH has been sitting for about 7 months and today I fired her up with no problems. I have a question on the Freedom Remote Control Panel. As long as I'm plugged into shore power it is lit up showing battery state, DV Volts, DC Amps and incoming AC Breaker Amps, but when I shut down the shore power it shows nothing. Is this the way it is supposed to be? Sorry but it's been awhile since I've used her.
2001 Trade Winds 7390
Toad 03 Grand Am
MountainAir05
New Mexico
Posted: 09/11/20 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
Check your battery voltage off the batteries.
cavie
Posted: 09/12/20 01:48am Link  |  Quote  |  Print  |  Notify Moderator
turn your battery disconnect on.
dougrainer
Carrolton, Texas
Posted: 09/12/20 04:31am Link  |  Quote  |  Print  |  Notify Moderator
Will NOT affect Inverter display function. The Inverter is connected DIRECT to the coach batteries as is the Display panel to the Inverter. His batteries are dead or DRY. The display will hibernate after a few minutes. But if the display goes OFF as soon as he disconnects 120 power, he has battery problems. Doug
SGTJOE
Utah
Posted: 09/12/20 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
My 6v GC2 batteries are reading 6.4 and 6.3 I have 4 and that is what they are reading
MountainAir05
New Mexico
Posted: 09/12/20 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Read Doug's post if you have not. Also run the trouble shooting in the manual.
MrWizard
Traveling
Posted: 09/12/20 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
6.3-4v per battery across one pair of battery posts,
That's 12.6 to 12.8 per pair and OK
But 6.4v. From ground to main positive
Means the batteries are dead
Main ground to main positive for the RV is 12.8 for full charge,
Radiate The Happy
1997 F53 Bounder 36s
dougrainer
Carrolton, Texas
Posted: 09/13/20 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Reading the CORRECT Posts at the batteries should yield 12.6/8 volts. EACH 6 volt battery will read what you posted. I would say you have connected the 4 batteries incorrectly and are NOT providing 12 volts to the RV as required. Hence, your Xantrex panel does NOT read. Doug
howdy35
Athens, Texas
Posted: 09/14/20 07:28am Link  |  Quote  |  Print  |  Notify Moderator
I have a 99 Tradewinds and had a similar problem after having some service done on my unit. I found a cable had not been reconnected and had nothing showing when I got off shore power. After checking battery water and charge on each battery, check to see that the cables are on correctly and tight. If you are not sure of cable hookup, check google, utube for help. Happy travels. Arnold
1999 National Tradewinds 7370
2014 Honda CR-V--Toad
Fulltime
SGTJOE
Utah
Posted: 09/14/20 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Taking her in this morning to have everything checked out. Thanks for all the replies.
