RV.Net Open Roads Forum: Fifth-Wheels: tire pressure
 > tire pressure
Rich&Mar
wa usa
Posted: 09/11/20 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
do you run the max pressure in your tires as written on the sidewall? I have the Endurance, and it states 80# psi. Seems to me you need to take the outside temperature into consideration. I an reluctant to inflate to 80 psi and go on the road when it's 90% out. Then it becomes a guessing game, what psi at 90, at 75, at 45 degrees. 8200lb 5er. The sidewall does read, max pressure, so should you put less due to the temp? Or let the pressure go well over the 80 because of the heat?
rich
Old-Biscuit
Verde Valley
Posted: 09/11/20 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
MAX PSI/Max Load Ratings is based on COLD Inflation...not driven on for 2 hours
Increase in PSI is already incorporated in Max PSI/Max Load Ratings
Check/Adjust tire pressures in AM prior to travel.
Leave it alone during travels --- check/adjust again next travel day
What is the weight on your trailer axles?
Where do you get that 8200# 5vr number?
What are 5vr axle ratings...5200#, 6000# etc?
What is the max load rating on those tires?
80# (Max PSI) would be needed IF---IF weight on tires was at/near Max Load Rating
fj12ryder
Platte City, MO
Posted: 09/11/20 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
^^^^^^^^^^^What he said.
Howard and Peggy
"Don't Panic"
CapriRacer
Somewhere in the US
Posted: 09/12/20 06:07am Link  |  Quote  |  Print  |  Notify Moderator
Just so everyone knows: The burst pressure of a tire is many times the max pressure. Unless a tire is on fire, there is no risk of the tire bursting on its own without it being damaged by some object - even in Death Valley!
CapriRacer
Visit my web site: www.BarrysTireTech.com
MFL
Midwest
Posted: 09/12/20 06:11am Link  |  Quote  |  Print  |  Notify Moderator
I agree with Old-Biscuit. Tires need to be adjusted to proper psi when cold. Yes, they will heat up rolling down the road, especially in the heat of the day. Keeping an ST tire at max pressure, as read on the sidewall will keep them cooler, get best mpg, due to less rolling resistance. For this reason, I never suggest to way over tire your trailer. An example...If you put G-rated tires on that FW, I would not suggest to air them to 110 psi, nor would I say just run them at 70 psi, per the inflation chart. That would simply not be the right tire for the weight of the trailer.
If your FW weight mentioned 8,200, is dry wt it will likely weigh 10K when loaded to travel, and even though the truck will carry about 2K of the weight, I'd still use 80 psi cold pressure.
Jerry
MFL
Midwest
Posted: 09/12/20 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Interesting...I know it would vary, all ST tires not being equal, in quality and design, but what would you consider a possible psi bursting point of the OPs GY Endurance E-rated tire, if air is continuously added? I know you can not give an exact psi, but maybe a range of psi guess?
Jerry
MNRon
Tennessee
Posted: 09/12/20 07:48am Link  |  Quote  |  Print  |  Notify Moderator
If your 5er is properly tired, I’d recommend airing up to sidewall psi (cold) as stated above and then using some type of TPMS to ensure it doesn’t start dropping precipitously. If you’re properly tired, you don’t have to worry if you get up on a cold day and it’s 5psi lower, you just drive. But again, recommend you inflate to sidewall psi and use TPMS
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
Near Annett’s Mono Village, Bridgeport, CA
Posted: 09/12/20 08:53am Link  |  Quote  |  Print  |  Notify Moderator
I want my Load Range D TT tires running at their max weight capacity...65 psi.
Allworth
Orlando, FL
Posted: 09/12/20 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Overthinking tire pressure is one of the most common sports among RVers.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
jjj
Lancaster,Ca.U.S.A.
Posted: 09/12/20 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
I have notice on my car a max of 2 psi difference if it was 70 or 90 degrees out as long as they are not getting direct heat from the sun on the tires. I run mine always at 80 and never had a problem except for my last set of Michelins that the sidewall started failing at just over 6 years. No more Michelins for me I am now replacing with Endurance soon.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
 > tire pressure
