RV.Net Open Roads Forum: Travel Trailers: RV Water heater
 > RV Water heater
jpmyers
Posted: 09/12/20 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Our New TT (May-2020) has a Electric/Propane water heater that has become very noisy lately. If only it were not right next to the bed. But it is and the 2' proximity with a very thin wall for seperation makes it difficult to sleep until it completes it's cycle.
Am I needing to clean the water heater out or change the annode? My ony experience is with home water heaters and I'm not sure what I need to do here.
Jerry & Pamela
2020 Highland Ridge Silverstar ST324RLS-38' Tag-A-Long
2020 1500 w/Max Haul package & Airlift air bags.
BobsYourUncle
Calgary Alberta Canada
Posted: 09/12/20 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Speaking for myself, I turn it off at night so I don't have to listen to it run.
Water will stay hot for quite a while, and still plenty warm in the morning.
I just flip the switch when I get up in the morning to make my first coffee and let it cycle.
The anode is not related to the sound it makes running.
Dmax/Allison
1997 Triple E Topaz 27' Bunkhouse TT
I do
Precision Guesswork
based on
Vague Assumptions
Unreliable Data of Dubious Accuracy
provided by persons of
Questionable Intellectual Capacity
Now, What would you like done?
CA Traveler
The Western States
Posted: 09/12/20 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Maybe it needs cleaning or adjusting. Otherwise just turn it off at night.
2014 Grand Cherokee Overland
Bob
jpmyers
Posted: 09/12/20 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Sorry to be a pest but what is involved in cleaning out the water heater? Open the PSV and flush?
bukhrn
Lanexa, Va
Posted: 09/12/20 09:31am Link  |  Quote  |  Print  |  Notify Moderator
I never turn mine off when camping, but then mine isn't next to my bed, but if it were, I'd agree with the others and just turn it off before retiring.
Do I assume it's only noisey when on propane ? I've never heard mine when on electric.
2007 Forester 2941DS
2014 Ford Focus
Near Annett’s Mono Village, Bridgeport, CA
Posted: 09/12/20 11:02am Link  |  Quote  |  Print  |  Notify Moderator
I’m not “afraid” of my TT water heater but I’ve never left it on, propane or electric, overnight. Yes, the fridge is on however. Fill and drain twice is the only flushing I’ve done, once a year or so.
jdc1
Rescue, Ca
Posted: 09/12/20 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Yep. Just shut it down.
Old-Biscuit
Verde Valley
Posted: 09/12/20 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
What Brand AND Model????
ONLY Suburban uses an 'anode rod' ----NOT Atwood
To drain/flush
Turn water supply OFF
Relieve system pressure by opening a Faucet Hot/Cold Sides-----leave it open
Remove drain plug ---water WILL flow out emptying the WH Tank
I turn water supply back on ---turn faucet off and let water Blast out WH TANK drain hole. CAUTION: Stand Back as it will BLAST out
Turn water supply back off....install drain plug (new anode rod if Suburban) and open faucet hotside to bleed air out of plumbing system and allow WH Tank to fill.
Water flows/no air from faucet-----done
Nosey FLAME on water heater
Atwood has an adjustable air shutter
Suburban no air shutter so could be dirty orifice, dirty burner tube etc
WHAT water heater do you have????
2edgesword
New York
Posted: 09/12/20 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
If it's electric and propane run it on electric.
BB_TX
McKinney, Texas
Posted: 09/12/20 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
Agree. No noise on electric. If the weather is cold we run the WH on both electric and propane at the same time to improve recovery rate. And the electric keeps the water hot enough that the propane never comes on unless we are using enough hot water at the time to require propane to help reheat the water. So no noise at night.
 > RV Water heater
