RV.Net Open Roads Forum: Tech Issues: Atwood water heater won't stay on.
 > Atwood water heater won't stay on.
Paul1944
Blanchard, OK
Posted: 09/12/20 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Just bought a barely used 2017 Shasta Oasis camper, hope I didn't buy somebody else's problems. Anyway, the Atwood water heater will not keep running after it kicks on, it stays on for only about a minute or so then it shuts off for 10-15 minutes before it kicks back on again. When I look in from outside there is nothing that I can see that would cause this such as spider webs or wasps nests. I did notice that when I first turn on the switch inside the camper the "DCI-FLT" light comes on. Any ideas or suggestions?
Paul & Margie
enblethen
Moses Lake, WA
Posted: 09/12/20 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Could be thermostat or ECO going open. Use an Ohm meter immediately after shut down check for continuity.
Could be the probe for the ignitor/flame sensor is not in the flame. It should be red hot.
Possible that the flame tube has restrictions. Remove and clean good.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Old-Biscuit
Verde Valley
Posted: 09/12/20 11:52am Link  |  Quote  |  Print  |  Notify Moderator
RED Fault Light is triggered when flame fails to light and PROVE it lit
Flame Rectification ---milliamp signal generated
Spark electrode provides high voltage spark for ignition AND is return path for that milliamp signal
*Electrode must be CLEAN---soot/carbon removed using emery cloth
*High Voltage wire connection at transformer on circuit board clean/tight
*High Voltage wire not loose in the ceramic insulator
*Ceramic Insulator --no cracks--milliamp signal will go to ground and circuit board won't receive it
*electrode must be engulfed in flame
*spark gap 1/8" - 3/16"
When flame lights off......is flame BLUE and quiet (very slight roar)?
IF NO
Might need to adjust air shutter ---typically only needs to be roughly 1/4 open
Might need to clean orifice (soak in alcohol/air dry), clean burner tube (small bottle brush)
Is this a GAS Only Water Heater OR GAS/Electric Combo?
Gas only vs Combo use different wiring systems
So what is MODEL?
US NAVY------USS Decatur DDG31
trailrider
Idaho Is Full! Don't Move Here!!!
Posted: 09/12/20 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
The obvious question is: "Is the water heater full of water?"
2020 Chevrolet Silverado 3500HD GAS!!!
1978 Chevrolet Silverado K20 4x4
2007 Komfort 277TS
2020 Sherco 300 SEF Factory
2018 Honda Rancher TRX420FA6
2017 Montesa 4RT260
2021 Honda CRF450X
jmerritt
Evendale, Ohio
Posted: 09/13/20 05:58am Link  |  Quote  |  Print  |  Notify Moderator
Could be something as simple as corroded connections turn off water heater and remove and reinstall each connection after putting some dielectric compound on each one.
2004 Holiday Rambler Presidential 5th Wheel 32'
Paul1944
Blanchard, OK
Posted: 09/13/20 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Model is GC6A-8E
I found a mud dobbers nest in the flame tube, cleaned it out as best I could, thought my problem was solved but WH only ran 5 minutes before shutting back down.
Paul1944
Blanchard, OK
Posted: 09/13/20 10:39am Link  |  Quote  |  Print  |  Notify Moderator
How can I reply to a specific response? I would like to answer Old-Biscuit questions directly.
Paul1944
Blanchard, OK
Posted: 09/13/20 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Yes.
Paul1944
Blanchard, OK
Posted: 09/13/20 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Model is GC6A-8E
Flame is more orange than blue.
There is a wire with what looks like a resistor in it, what is that for?
Model is GC6A-8E
There is a little wire with what looks like a resistor in it, what is that for?
IF NO
So what is MODEL?
Old-Biscuit
Verde Valley
Posted: 09/13/20 11:41am Link  |  Quote  |  Print  |  Notify Moderator
"Model is GC6A-8E
There is a wire with what looks like a resistor in it, what is that for?"
8E has separate controls for electric & gas
ELECTRIC:
120VAC comes from a Circuit Breaker to on/off switch (backside of WH Tank) then thru set of T-stats to element (also backside of WH Tank)
GAS:
12VDC comes from Fused source to 'thermal cut out' (fuse in clear tubing----it blows at 190*F if flame blowback occurs and stops ALL DC to water heater. One shot device --replace if bad)
From thermal fuse DC goes to/thru TT-stat then to circuit board
Circuit Board then sends DC to ECO/Gas Valve AND spark electrode
Posted earlier
IF NO (YOU stated more ORANGE then Blue)
