RV.Net Open Roads Forum: 2016 RAM CTD Diff Oil Change Question RE Gasket
Search only in Tow Vehicles
 > 2016 RAM CTD Diff Oil Change Question RE Gasket
Posted: 09/14/20 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
agesilaus wrote:
The advice I got on my F350 was to use the Permantex Differential gasket gunk and forget the gasket. It's worked so far on both differentials
In a pinch, I've used silicone window caulking or manhole mastic in similar applications.
And I've heard the "Right stuff" gasket maker works awesome.
But that was't the question and reusable rubber gaskets are a nice departure from smearing gasket goo on surfaces.
wanderingbob
monticeeo, fla
Posted: 09/16/20 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Can you not suck the oil out and not open the case ?
FishOnOne
The Great State of Texas
Posted: 09/16/20 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
You sure can as this is the method most dealers use. Unless there's a drain plug.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
Cummins12V98
on the road
Posted: 09/16/20 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
"And I've heard the "Right stuff" gasket maker works awesome."
It's DA CHITZ!!! NEVER had a leak using it.
I do reuse my gasket on my 15 DRW RAM.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
blofgren
Surrey, B.C.
Posted: 09/16/20 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
But you won’t be able to have a look at the ring and pinion and clean the magnet. Not good IMHO.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
Posted: 09/16/20 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
Bingo!
Better than not maintaining it, but not as good as doin it right.
goducks10
There
Posted: 09/16/20 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
x2
Cummins12V98
on the road
Posted: 09/17/20 09:44am Link  |  Quote  |  Print  |  Notify Moderator
"But you won’t be able to have a look at the ring and pinion and clean the magnet. Not good IMHO."
Even when I was running a MagHytec that has drain and fill plugs I always removed the cover for inspection.
Learjet
Louisiana
Posted: 09/19/20 07:51am Link  |  Quote  |  Print  |  Notify Moderator
you'll have the magnet/plug out to add fluid...so yes you can clean the magnet.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
CharlesinGA
South of Atlanta, Georgia
Posted: 09/21/20 11:10am Link  |  Quote  |  Print  |  Notify Moderator
The cover is 14 bolts. It is a metal and rubber, reusable seal, so unless it is damaged in some way, it should be just fine. Carefully wipe it off and examine both sides of it. New ones are expensive, about $45 or so. There are no drain plugs and you should pull the cover and examine the insides.
Do NOT use any sealer on this seal, just wipe it off and possibly wipe a fresh film of gear oil on it.
GM uses the same basic rear end on many models but they use a throwaway gasket.
Charles
