RV.Net Open Roads Forum: Class A Motorhomes: Rear AC - BAD vibration-Solved
 > Rear AC - BAD vibration-Solved
RJL
Manahawkin, New Jersey
Posted: 09/12/20 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Went camping last week for a week or so. The rear roof ac was vibrating the entire coach pretty bad. I thought great, another thing to fix, get fixed or replace over the winter.
Got home and googled possible causes. I took the cover off and checked the fan for any excessive play, comparing it to the front ac. Seemed normal. Stuck my hand behind the fan blades to check for mud wasp nest(s), nothing.
I took off the top of where the coil sits and felt around to the hub where the blades come together and Eureka! Big mud wasp nest. Removed it and unit runs smooth again.
Just wanted to leave this here should anyone need a search in the future.
Bob
* This post was edited 09/12/20 09:52pm by RJL *
2010 Damon Challenger 368, F-53 Chasis
2010 Jeep Wrangler Rubicon unlimited, Toad
2018 Ram 1500 4x4, Club Cab, 6.4 bed,3.92 gears, 5.7 HEMI
2019 Dodge Challenger Scat Pack Wide Body, 6.4 HEMI
Fulltimers
Anywhere, USA
Posted: 09/12/20 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
Ha. I had a vibration also. Ever so slight but still a vibration. I took the cover off and noticed the fan and motor shaft was vibrating. I reached in to see if I could hold the motor stable and BAM! I got my knuckle in the fan and took off the top of my knuckle and 2 blades off the fan. Ordered a new fan and installed it. Now everything is quiet and steady and the knuckle is healing just fine.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2005 Saturn Vue (Mr. Toad)
3.5L V6 Automatic
Executive
Posted: 09/13/20 12:38am Link  |  Quote  |  Print  |  Notify Moderator
Hope you wore gloves. Nothing gets ones attention faster than grabbing a full wasps nest with a bare hand....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Wherever I happen to park
Posted: 09/13/20 04:46am Link  |  Quote  |  Print  |  Notify Moderator
1: Insect nests are #1 cause of this
2: Fan failure is #2
3: NEVER EVER mess with it while it's running.. LOOK but do not touch.
Home is where I park it.
