RV.Net Open Roads Forum: General RVing Issues: Flying Floating Flooring
 > Flying Floating Flooring
JimK-NY
NY
Posted: 09/14/20 10:35am Link  |  Quote  |  Print  |  Notify Moderator
magicbus wrote:
JimK-NY wrote:
...I can and have pulled the entire piece of carpeting out of the RV for cleaning. When it gets really dirty, I hose it off and even use a broom with soapy water.
And there is one of the best selling points for using a wood product or vinyl instead of carpet.
Dave
Not really. As I said I already have vinyl flooring. It is still in like new condition. Even so I prefer the carpeting. I like being able to get up in the middle of the night and not freeze my feet on a cold floor. I enjoy taking off the hiking shoes or boots at the end of the day and walking around in stocking feet.
A thorough cleaning is really easy. I just pull out the carpeting and shake it or use the old fashioned cleaning by hanging the carpet over a line and beating it. The ultimate is soapy water and a hose but I rarely do that since it will take a sunny day and a couple of hours of drying time.
campigloo
Baton Rouge, La
Posted: 09/14/20 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
I think what he’s talking about is resilient tile. Super easy to install and looks good. Cut it with a utility knife. You don’t need expansion joints and water doesn’t phase it. You would still want to make accommodations for the slide rollers.
aftermath
Washington State
Posted: 09/14/20 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Just sent you a PM.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
Deb and Ed M
SW MI & Space Coast, FL USA
Posted: 09/15/20 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Some random thoughts: at least 15 years ago, I installed peel-and-stick "oak" vinyl planks in our (house) bathroom, I think they were made by Congoleum; and they have endured all these years and still look nice.
Last year, we had Home Depot's "Life proof" vinyl planks installed in our condo - one of the things I noticed was that they didn't have to be "acclimatized" by sitting inside for a few days before installation. Implies to me that they don't shrink or expand as much as other flooring? The drawback is the thickness of each plank - they are at least 1/4" thick, which might interfere with a slideout.
Last thought: depending on whether the RV is a trailer or MH, there could be uneven heat sources (like exhaust pipes) under the floor. I saw a converted van, whose owner has installed vinyl "coin flooring" and it bubbled up where it was laid over the cat. converter.
cummins2014
Utah
Posted: 09/15/20 11:25am Link  |  Quote  |  Print  |  Notify Moderator
I agree , 1/4" might be an issue , but as far as going over that 1/4" , I don't think in my case it would be an issues , there is actually a raised portion just as the slide goes over into the flooring, and that 1/4" would actually be below that slightly. As far as the slide out goes there is enough movement in them 1/4" raised up as it goes in, I wouldn't think its an issue. The rollers on a hard surface is the only issue, and those slickers can cure that. Although that laminate flooring is much tougher then that cheap linoleum they put in a lot of RV's
Reisender
NA
Posted: 09/15/20 11:37am Link  |  Quote  |  Print  |  Notify Moderator
ThruTraffic wrote:
Have any of you ever installed floating flooring in your RV and glued it in place?
No need for hundreds to pile on with the mfgr said this and that and no you can’t do it because the warranty is gone and yada yada yada. I know one isn’t “supposed“ to glue floating floors.
I’m asking in this context:
- Floating floors are designed to float because of expansion; the reason a 1/4” gap is left around the perimeter.
- BUT, is expansion really an issue in such a narrow installation like a motor home??? The widest part of my RV’s floor is about 6’.
I understand the necessity of considering expansion in a home with a large room. But what if one were simply doing a four foot wide hallway; which in most cases are around three to six feet wide. If one could glue a hall, one should be able to glue in an RV.
I don’t think the weather extreme argument holds or the manufacturer would warn against installing their products in vacation homes where inside is like outside when no one is in residence and then fired up the furnace/AC a few times a year.
I’ll add a line or two about why I’m asking: I’m concerned that the rollers on the slide out may push the flooring ahead of it, and the worst case scenario would be when they push the flooring till it stops against the far wall it could then push the flooring until it “accordions”. When a roller under load is given enough inertia to move it has to be forced to roll; it doesn’t want to by itself; it digs in like a kid being pushed towards the bathroom to brush their teeth, then it will roll. If the floor is glued this concern doesn’t exist.
Yes...sort of. I mitigated the floaty thing by fastening the first board on one side. That was 10 years ago. This stuff is as tough as it comes. Dogs, wet feet, all season, (we were full time for years). Not sure if this is what you wanted to hear but its my contribution.
Side note, we installed the underfloor heating pads. Total of a few hundred watts but feet are always toasty in winter.
And yes we installed under couch lighting. Nice for movie nights etc. This is in our 2003 Revolution we have had since new. Looks as good now as it did then...at least inside. Paint job is kinda shot. Meh. Still runs great after 155K on the clock. Woohoo. [emoticon]
cummins2014
Utah
Posted: 09/15/20 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
Could you elaborate on the install , is there slideouts involved, thickness of the material. How was the one side fastened down , nailed , glued ?
