RV.Net Open Roads Forum: Class A Motorhomes: 2007 Allergo 32 BA Wipers
 > 2007 Allergo 32 BA Wipers
haste maker
alabama
Posted: 09/12/20 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
My wipers quit working, I have checked the plug-in with a test light with the key in the run/power position & wiper switch in the run position, there isn't any power at the plug-in, also nothing happens when I push the window wash button on the wiper switch...I am guessing the switch is bad...anyone have any other thoughts on what the problem could be?
Retried Teamster
2007 Allergo
MountainAir05
New Mexico
Posted: 09/12/20 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have power to the switch.
Google this "Ford RV wiper fuse location"
haste maker
alabama
Posted: 09/15/20 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Yes..but after checking with a new switch & still nothing...not sure about power to the switch...
* This post was edited 09/17/20 03:09pm by haste maker *
dougrainer
Carrolton, Texas
Posted: 09/15/20 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Class A Ford Wiper control module is located on the firewall between the steering column and the Gas pedal. Doug
Will look similiar to this.
https://www.forddiscountparts.com/oem-pa........_0ZXs6wIVuymzAB1kHwxfEAQYAyABEgK0dPD_BwE
* This post was edited 09/15/20 04:07pm by dougrainer *
haste maker
alabama
Posted: 09/17/20 06:17am Link  |  Quote  |  Print  |  Notify Moderator
Thanks didn't know there was a control module..
haste maker
alabama
Posted: 09/17/20 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
Doug..I didn't find a wiper control module in my unit, I checked with a Ford dealer & they said it was an Allergo item, so I called Tiffin & was told by the service dept. that my unit didn't have wiper control module ? I have replaced the switch & checked all the fuses...all were good...I also ran a hot wire from the battery to the motor & it ran....Thanks for your help.
dougrainer
Carrolton, Texas
Posted: 09/17/20 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
Is your switch mounted in the dash front or on the Turn signal? If Dash, does it have the center knob for OFF and Wiper speeds and the outer ring for the timing of the Intermittant? Doug
dougrainer
Carrolton, Texas
Posted: 09/17/20 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Usually the Wiper fuse is NOT in the FORD fuse box, but the added fuse box by Tiffin. Do you have the removable lid on top the dash behind the Instrument cluster? Doug
dougrainer
Carrolton, Texas
Posted: 09/17/20 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
ON the switch you replaced, one of the wires should be HOT when Key is ON. Doug
haste maker
alabama
Posted: 09/18/20 03:44am Link  |  Quote  |  Print  |  Notify Moderator
My switch is on the steering column it is a combination wiper/washer/turn signal/high beam switch...I have the fuse on top of the dash & it has a fuse marker wiper & that fuse is good.
