RV.Net Open Roads Forum: Class A Motorhomes: 2007 Allergo 32 BA Wipers
 > 2007 Allergo 32 BA Wipers
dougrainer
Carrolton, Texas
Posted: 09/18/20 06:52am Link  |  Quote  |  Print  |  Notify Moderator
haste maker wrote:
My switch is on the steering column it is a combination wiper/washer/turn signal/high beam switch...I have the fuse on top of the dash & it has a fuse marker wiper & that fuse is good.
THAT should have the Wiper control module. When you follow the harness connected to the wiper motor, does the harness go to a module? The older Fords may have the module on the outside of the firewall. Doug
haste maker
alabama
Posted: 09/19/20 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
I followed the wire from the switch to the big wire harness & from the motor to the big wire harness & there isn't control module on this RV for the wipers. It has been suggested that computer may have lost it's memory & needs to be replaced or re-flashed, so I guess the next step is a trip Red Bay, Al. and let them fix it...thanks for your help.
Retried Teamster
2007 Allergo
haste maker
alabama
Posted: 09/21/20 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all your help Doug...But I have found the problem this unit doesn't have a control module...but does have two fuse panels one on the firewall & one on the top of the dash. The one on top of the dash has a 20 amp fuse which was good...but the one on the firewall has a 15 amp fuse which was bad..this fuse only has a # was a pain to locate the #...but all is working now...
crasster
Dallas
Posted: 09/21/20 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
I'd go through each fuse one by one. Never hurts to check.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
