RV.Net Open Roads Forum: Fifth-Wheels: AGM upgrade
 > AGM upgrade
guinness1
Michigan
Posted: 09/12/20 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2012 Coachmen Chaparral. The original battery finally died. Can I upgrade to an AGM battery? Any other changes need to be made? Or is just “Plug N Play”?
2012 Coachmen Chaparral 330FBH
2011 Chevy 3500HD 6.0
Near Mammoth, CA
Posted: 09/12/20 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
You can change to an AMG. However, as others have written...
“AGM batteries are designed to be charged at a low rate and slowly. Unless your converter/charger can tell difference between an AGM and flooded battery it will charge the AGM like it's a flooded battery, which will work but it also will shorten the life of the battery.”
cummins2014
Utah
Posted: 09/12/20 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
The only thing I know about them is overcharging kills them.
corvettekent
Marysville, WA
Posted: 09/12/20 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
AGM is still a lead acid battery so no need to change your charging system. BTW you will not be upgrading by switching to the AGM as it won't last 8 years.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
theoldwizard1
SE MI
Posted: 09/12/20 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
8 years is fantastic life !
Upgrading depends on the converter charger you have. Likely it is a WFCO. Upgarding to a Progressive Dynamics with Charge Wizard will guarantee the maximum life of your new battery.
time2roll
Posted: 09/12/20 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
For best answers post your converter model number and the specific battery you intend to use.
675w Solar pictures back up
WNYBob
Tonawanda, NY
Posted: 09/13/20 05:50am Link  |  Quote  |  Print  |  Notify Moderator
I agree, as I upgraded to "Progressive Dynamics with Charge Wizard" as I lost 2 batteries with short life. Happy so far. I did add a cheap (China) monitor with a shunt to check voltages and amps.
theoldwizard1
SE MI
Posted: 09/13/20 07:30am Link  |  Quote  |  Print  |  Notify Moderator
As long as it is "reasonably" accurate, then it is worth what you paid for it. !
cummins2014
Utah
Posted: 09/13/20 08:24am Link  |  Quote  |  Print  |  Notify Moderator
I have a Cabelas AGM ,bought in June of 2012, still going . Have always charged it back up as soon as I was done with it. I can still get about 5 hours out of on my one man inflatable pontoon boat fishing.
obiwancanoli
Napa
Posted: 09/13/20 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Might want to consider a change to Lithium batteries... expensive, but, long term costs re generally lower, and features and advantages may outweigh initial cost. LifeBlue has a version which can be charged down to -4 degrees - typically, Li batteries can't be recharged below 32 degrees...
 > AGM upgrade
