RV.Net Open Roads Forum: Fifth-Wheels: AGM upgrade
 > AGM upgrade
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 09/13/20 11:09am Link  |  Quote  |  Print  |  Notify Moderator
If you change to Lithium, almost positive it will require a change to your Converter, because Lithium is the battery that requires special charging.
I recently changed to AGMs and contacted Progressive about my converter and was told I was good to go.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Veebyes
Posted: 09/17/20 11:20am Link  |  Quote  |  Print  |  Notify Moderator
corvettekent wrote:
AGM is still a lead acid battery so no need to change your charging system. BTW you will not be upgrading by switching to the AGM as it won't last 8 years.
If you don't already have one a multi stage, multi battery chemistry, battery charger is advisable.
Coming from the marine world, where you don't want batteries gassing into the bilge of your boat, I am a big fan of AGM batterys.
Expect up to 3 times the service life out of an AGM compared to a wet cell. I got 9 seasons out of my 4D Lifeline. It performed well to the end when death was quick. It was never left on a battery tender during its typical 5 months of storage each year.
2019-2020 the battery was left without any attention for 9 months & had power to operate 5er legs & slides before it was connected to a charger.
No they are not cheap. The payoff is in years of maintenance free service.
2007 Alpenlite 34RLR
 > AGM upgrade
