RV.Net Open Roads Forum: Tech Issues: Correcting flipped shackles
 > Correcting flipped shackles
pulpwood007
Hemphill, TX
Posted: 09/12/20 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
While trying to grease wet bolts by lifting the trailer I accidentally flipped the shackles on one axle. I've read of the various ways to correct, but usually involves putting pressure on the axle and forces the shackles back into the correct position, accompanied by a "loud bang".
Is there a less intensive way to do this not putting so much stress on the springs/shackles?
azdryheat
Tucson, AZ
Posted: 09/12/20 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Not that I'm aware of.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
msmith1.wa
Tacoma, WA
Posted: 09/12/20 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
The only other option I can think of is to remove one if the bolts on the shackle and reassemble in the correct orientation.
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
C Schomer
Pueblo West, Co.
Posted: 09/12/20 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
I helped a friend get their shackles un flipped and it helped to jack the trailer back up a little and use bars, like you did. I guarantee I'd find a permanent fix if it were my trailer. Either longer springs or move the outer spring mounts closer together... I've done both. Craig
pulpwood007
Hemphill, TX
Posted: 09/12/20 11:07pm Link  |  Quote  |  Print  |  Notify Moderator
C Schomer wrote:
I helped a friend get their shackles un flipped and it helped to jack the trailer back up a little and use bars, like you did. Craig
I have never used a bar. What is the process? That's what my question is.
opnspaces
San Diego Ca
Posted: 09/12/20 11:19pm Link  |  Quote  |  Print  |  Notify Moderator
I too would pull a bolt, flip the shackle and put the bolt back in.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
2naEagle
McCalla, AL
Posted: 09/13/20 05:49am Link  |  Quote  |  Print  |  Notify Moderator
Hook up to the truck and run one wheel up on a couple of boards. It should pop back in place.
Here's a video showing using a jack. I have helped a couple of people in campgrounds do it by running it up on boards. It will scare you when it goes back in place.
https://www.youtube.com/watch?v=mQrDd4tDkv8
2020 F350 Limited CCSB SRW
2017 North Point 315RLTS
2021 Jayco Redhawk 24B
pulpwood007
Hemphill, TX
Posted: 09/13/20 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
That would be my preference, and particularly since I need to reposition a wet bolt that won't take grease.
Problem is I really don't have large enough jack stands to support the trailer. That concerns me.
C Schomer
Pueblo West, Co.
Posted: 09/15/20 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have two pneumatic cylinders that I can lift trailer with and when I get the shackles to where they were close to flipping back i used a wrecking bar to help flip them. It still wasn’t easy because Id move the shackle on one side and the shackle on the other side Usually wanted to go the wrong way but I still got them right and it didn’t take very long. Craig
