RV.Net Open Roads Forum: Needing help, evacuated, battery dead
Open Roads Forum  >  Class B - Camping Van Conversions  >  DIY
 > Needing help, evacuated, battery dead
pianotuna
Regina, SK, Canada
Posted: 09/13/20 11:35am Link  |  Quote  |  Print  |  Notify Moderator
For now.
1. start the engine on the class B
2. wait 1/2 hour
3. attempt to start the generator
4. if it starts, add a battery charger to recharge the house battery bank when ever running the generator.
For the future
make sure the converter is working correctly.
Regards, Don
time2roll
Posted: 09/13/20 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Also get a voltmeter so you can monitor the situation better.
We can help more if we had some battery voltage data.
675w Solar pictures back up
Woodsie8*
pnw
Posted: 09/13/20 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
Thx everyone! As soon as I can my hands on a volt meter, I will problem solve more. I am rethinking a lot, for future events. Maybe get a second battery, or add at least one solar panel, not ask as much from the house battery, get a portable battery booster/charger. Maybe get a second generator for the house but that seems unneeded.
opnspaces
San Diego Ca
Posted: 09/13/20 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
You do not need a second generator.
Where or how would you hook this second generator up? However you are envisioning hooking up the second generator will be the same for the existing generator.
Number one, turn off the generator, find the circuit breakers in the house and find the one that is tripped and not charging the battery. If you can't find the specific charger circuit breaker then turn them all off.
Now push extra hard on any breakers that seem to be springy or have any sponginess until it snaps all the way off. Now turn all the breakers back on.
Once the breakers are all back on, turn on a light or two and maybe turn on a ventilation fan as well. Now start the generator and see if the fan speeds up and the lights get brighter. If the fan speeds up and the lights get brighter you have probably fixed the house battery charging.
If you still can't get the house battery charging, then buy one of these Link, and plug it into the trailer or directly into your generator. Then plug the trailer shore power cord into the end. This will charge your house battery until you can get a multimeter.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
time2roll
Posted: 09/13/20 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
If your were evacuated I am not sure why you are at home trying to run a bunch of freezers.
I would be tempted to just leave.
Woodsie8*
pnw
Posted: 09/13/20 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
Second generator was going to be for home, to handle freezer/frig in outage in future instead of using RV generator to keep them running.
Thanks for the steps! I will try that.
Woodsie8*
pnw
Posted: 09/13/20 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
We went between be ready, get ready and leave. While I was in the RV waiting to be evacuated, I plugged them into RV, then killed battery. Once evacuated, they were not hooked to RV but still frozen but after that, no power @ home, no battery on RV. Was just trying to figure out for future what I can do for extended periods of outages. Hook to RV with RV generator going, , buy another house generator, solar, etc.
time2roll
Posted: 09/13/20 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
How about put them on a small utility trailer(uhaul?), connect to the van, and just go. Plug them all in at a comfortable RV park until you get word the power is back on.
Woodsie8*
pnw
Posted: 09/13/20 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
I am not that vested in saving the food [emoticon]
I think I am more trying to figure out for extended outages in the future. Hoping not to get evacuated again!
time2roll
Posted: 09/13/20 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
Need a roof? Tesla solar roof plus a few power wall batteries. Works for you even when the power is on. big $$$ up front.
Otherwise maybe a home generator and 500 gallon propane tank.
Or get the RV systems working. Consider adding a home transfer switch and power inlet to make living without power plug and play.
