RV.Net Open Roads Forum: Fifth-Wheels: Cleaning the carpet?
 > Cleaning the carpet?
riltri
Lansing
Posted: 09/13/20 05:49am Link  |  Quote  |  Print  |  Notify Moderator
Our Brookstone has vinyl plank flooring but the slide-outs & bedroom are carpeted. Without renting a carpet cleaner, what is the best way to clean the carpet?
* This post was edited 09/13/20 09:07am by riltri *
gbopp
The Keystone State
Posted: 09/13/20 06:47am Link  |  Quote  |  Print  |  Notify Moderator
It's not what you want to hear but, we hire Stanley Steemer for our home and RV.
We've found them to be the best carpet cleaners. Watch for their specials. YMMV
TXiceman
Full Time RVer
Posted: 09/13/20 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Stanley Steemer or rent a Rug Doctor cleaning machine.
Ken
Amateur Radio Operator.
pigman1
Delaware
Posted: 09/13/20 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Our RV has over 110,000 miles on it and has been to Alaska 5 times and the southwest 7 times. Those trips to Alaska were to Valdez where we fished in the rain more than 50% of the time. That said, our light colored carpet on the slides, under the table and especially in front of the refrigerator gets very dirty. We use the carpet cleaner RESOLVE. Brush it in with a stiff brush, let it dry, and vacuum it up. The dirt and spots come up with it. OUR CARPET, in all areas, LOOKS LIKE BRAND NEW.
One caution, the dry RESOLVE powder clogs vacuum bags easily because it's so fine, and then they blow out, so check them often and replace after carpet cleaning. We use a Dyson... No bags.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
BarneyS
S.E. Lower Michigan
Posted: 09/13/20 08:46am Link  |  Quote  |  Print  |  Notify Moderator
I agree with Pigman regarding the Resolve and also the Dyson. I had to take our Dyson completely apart and clean it with soap and water and then blow with air compressor to get all the powder out. The carpet did come out very clean however. [emoticon]
Barney
Not towing now.
jdc1
Rescue, Ca
Posted: 09/13/20 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Buy a Bissell. It only takes 2-3 times renting to pay for one you can own. I use mine to clean mt RV carpet. I even make my own shampoo.
riltri
Lansing
Posted: 09/13/20 09:05am Link  |  Quote  |  Print  |  Notify Moderator
What do you think RESOLVE powder would do to a wet/dry ShopVac that uses a bag filter?
Gearitis
Waco TX
Posted: 09/13/20 09:16am Link  |  Quote  |  Print  |  Notify Moderator
We usually rent a Big Green Machine with upholstery atachments and pick up ZEP Commercial Carpet Cleaner at Home Depot. Also use ZEP Carpet spot remover prior to the carpet cleaning on those tough spots We get in the corners and hard to get spaces with the upholstery attachment and get the big areas with the machine. We then use it on the truck and any other vehicle upholstrey as well as the sticks and brick if we are there. One Day rental is 40 bucks and a gallon of Zep is 9 bucks which last forever! Spot remover about 8 bucks for a gallon and again last a long time. Been doing this for years from our Class A to TT now the 5er. It smells fresh and clean and the Big Green Machine is strong enough to pull out most sand and other garbage in the carpet. We had a small dog for years and it worked well.
2015 F-350 King Ranch
2015 Sabre Silhouette Select 312RKDS
pigman1
Delaware
Posted: 09/13/20 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Other than dumping the Dyson dirt chamber, we do NOT clean it in any other way. However, ours is a small rechargeable. I have not tried to use a wet/dry on the Resolve, but it's got a filter, albeit very large, so I'd think it would probably clog as well. Just a lot slower and perhaps the dust could be cleaned out by beating the ends of the filter on a hard surface. My wet/dry uses a canister filter, not bag.
2oldman
New Mexico
Posted: 09/13/20 11:59am Link  |  Quote  |  Print  |  Notify Moderator
The only satisfactory cleaning I've ever got is from a commercial cleaner with a truck-mounted unit. Less than $100. Of course it's cheaper (and more work) to do yourself, but it won't get as clean, and those guys will do your furniture and throw rugs too.
Is that renting a carpet cleaner?
