RV.Net Open Roads Forum: Fifth-Wheels: Cleaning the carpet?
 > Cleaning the carpet?
Tyler0215
Iowa
Posted: 09/13/20 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
I use a garden sprayer with a little bit of Simple Green. Spray, scrub with a soft brush and vacuum with a shop vac. Rinse with clean water and vacuum again. Done.
Campinfan
Washtenaw County, Michigan
Posted: 09/13/20 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Little Green Machine, it is portable. I use it at home for spot cleaning but I have used it in the trailer because there is not that much carpeting. Even in our bedroom, which has the most, it does not take that long.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
DianaPowell
USA,NY
Posted: 12/02/20 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
Everyone has a way to clean the carpet and I have no doubt that it works for them. I just had a sad experience with cleaning carpets on my own, I ruined an expensive Persian carpet that cannot be restored. After such a terrible failure, I use the services of cleaning companies. As for how to clean a carpet in a hotel, I can only advise you on carpet cleaning companies. I do not advise you to risk cleaning and experimenting yourself, because you can ruin it. Professional companies know their business and will do everything for you in a good way.
___________________________
carpetcleaningnyc.com
* This post was edited 12/14/20 07:55am by DianaPowell *
stripit
Prescott
Posted: 12/02/20 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
I have used Folex purchased at Home Depot, spray on a micro fiber and rub that on the dirty areas of the carpet. Really bad spot, spray directly on the spot, use a dry micro fiber cloth laid on the spot and use my foot with a shoe to pressure blot the area. Then vacuum, Folex worked really well on the ceiling areas where water leaked in at the a/c unit.
Stacey Frank
2016 Tiffin Allegro Bus 40AP
2019 Tesla Model X
2015 Cadillac SRX we Tow
1991 Avanti Convertible
