RV.Net Open Roads Forum: Travel Trailers: replacement air conditioner
 > replacement air conditioner
time2roll
Posted: 09/13/20 11:04pm Link  |  Quote  |  Print  |  Notify Moderator
120v:
https://www.amazon.com/WYS012-17-Air-Conditioner-Inverter-Ductless/dp/B01DVW6G06
675w Solar pictures back up
jshupe
FT
Posted: 09/14/20 07:29am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
I vote for the 240 volt inverter. Mini-Splits are the bomb!
Here is a 115 volt Mini Split.
https://www.homedepot.com/p/Pioneer-Low-........t-Pump-110-120V-WYT012ALFI19RL/314096172
Both of those are wall units - the OP is specifically requesting a cassette unit, which only comes in 240V as far as I've seen.
2015 Keystone Alpine 3730FB, 2019 Ram 3500 HO/AISIN CCLB DRW, 2020 JLUR
Primarily off-grid living w/ 2925W solar and 22.8kWh LiFePO4, 30K 240V multi-split,
a custom bladder/pump/monitor setup so we can use water as we wish, and more
pianotuna
Regina, SK, Canada
Posted: 09/14/20 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Chewydog,
There are 48 volt dc air conditioners. Some are mini splits.
Regards, Don
TurnThePage
North ID
Posted: 09/14/20 09:26am Link  |  Quote  |  Print  |  Notify Moderator
It's nice to see these options out there. Definitely expands my future RV choices.
2015 Ram 1500
2004 Pioneer 18T6
jshupe
FT
Posted: 09/14/20 09:34am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Chewydog,
There are two importers (as of a year or so ago) of these units in the US - I really, really wanted to go this route as I have a 48V system. For the OP, unfortunately neither import cassette units but one could probably be imported via Alibaba/Ebay or a similar source. But that brings me to my second point - because I wanted these units but couldn't find reviews on them, I went on Instagram to do hashtag searches and PM'd users who had installed them. The overwhelming majority of responses I received were to "stay away" because they seemingly all had issues. Just relaying the word of warning.
I went with a LG 240V multi-split, so that I can get parts if needed and because they had the most efficient condenser unit in the class. With the same 30K of advertised capacity as my rig came with, these cool and heat much better, and use a third of the energy in day over day comparisons. It's still possible to see them pull a combined 2.5kW at times (heating), but they do so for much shorter periods and typical draw is closer to 700W per 15K indoor unit, when running on high cool or less than half that once the room is close to the desired temp.
* This post was edited 09/14/20 10:10am by jshupe *
