RV.Net Open Roads Forum: Fifth-Wheels: Andersen and 6'4" Ram
 > Andersen and 6'4" Ram
Page of 5
spud1957
NB
Posted: 09/14/20 06:03am Link  |  Quote  |  Print  |  Notify Moderator
Looking at a Ram. Can anyone comment that has an Andersen hitch with the 6' box? What kind of clearance are you getting between the cab and tailgate. What's the orientation of the pin adapter?
Thanks
ford truck guy
Pennsylvania
Posted: 09/14/20 07:53am Link  |  Quote  |  Print  |  Notify Moderator
cummins2014 should be commenting shortly... He is an advocate for the Anderson and Ram..... He will be able to answer
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
cummins2014
Utah
Posted: 09/14/20 08:38am Link  |  Quote  |  Print  |  Notify Moderator
I can ,and I will. [emoticon]
A little more information would be helpful . I have towed two different fifth wheels with my rail mount Andersen. My previous Montana fifth wheel I had the hitch mounted with the ball furthest from the cab , also the adapter putting it furthest from the cab, no clearance problems with my 2014 Ram 3500 short bed. My present fifth wheel I have the hitch the same ,but the adapter putting the fifth wheel closer to the cab, still not an issue with clearance.
The clearance depends on a few things , where the pin box is mounted on the fifth wheel, some stick out further then others. How rounded the front cap on the fifth wheel is, giving additional clearance. . IMO the OP will not have any issues with clearance, especially with a newer fifth wheel ,and the hitch ,and adapter both in rear position to start.
I have yet to get into any situations where backing into a spot was a clearance issue. I was a little concerned this summer ,had to back into a pretty tight spot in an RV campground in Montana this summer. Not sure what degree of turning I did , but I would guess in the 65-70 degree range. Actually more then I want to, but it was on dirt, and gravel so not that big of stress on the fifth wheel suspension.
cummins2014
Utah
Posted: 09/14/20 08:57am Link  |  Quote  |  Print  |  Notify Moderator
PM sent
Cummins12V98
on the road
Posted: 09/14/20 10:17am Link  |  Quote  |  Print  |  Notify Moderator
"Secret Squirrel" [emoticon]
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ford truck guy
Pennsylvania
Posted: 09/14/20 11:01am Link  |  Quote  |  Print  |  Notify Moderator
NOW your showing your age.... the LAST episode of the aired in 1966!
I actually think that I may still have a comic book with Secrete Squirrel ?
MFL
Midwest
Posted: 09/14/20 11:11am Link  |  Quote  |  Print  |  Notify Moderator
He should be a good source of information, for what the OP is asking. I don't see a lot of options for the Ram axle center to cab, being a short distance. I don't know if this Ram has the puck system, or if rail system is being considered, but I do not think a single point attachment is the best option. IMO, Andersen with rails may work, a B&W Patriot with rails, adjusted to rear setting, may work. Using a standard hitch, with a sidewinder type pin box will work.
The OP is a pretty smart guy, and is asking lots of questions before taking a leap. Once he gathers good info from others, I think he will make the best choice available. Moving to a used diesel, I think his truck choice is a wise decision.
Jerry
cummins2014
Utah
Posted: 09/14/20 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
The truck choice is a great decision ,as well as the Andersen. I agree I am no fan of the aluminum, only because I also don't think they are the best option, the single point attachment, Although many do like them. I have the Reese frame adapter attached to the puck system ,and the steel rail mount Andersen.
At one time Andersen was considering a four attachment hitch to fit these puck systems. It would be the best of two worlds, but that was two years ago when I communicated with them, apparently they have scraped that idea .
I have entertained the idea of converting that steel Andersen to attach directly to the puck system, eliminating a bunch of the frame work of the Reese adapter, welding parts of it directly to the Andersen, I have the means to do it. But the big problem is its defeating the purpose why I bought it, so I could remove it away from home. I fish with a one man inflatable pontoon boat, and need the hitch out of the way to transport the boat when camping .
cummins2014
Utah
Posted: 09/14/20 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
I was graduating from high school that year, had other things on my mind, but it was not comic books [emoticon]
ford truck guy
Pennsylvania
Posted: 09/14/20 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
I WAS 2 !
Page of 5
