RV.Net Open Roads Forum: Fifth-Wheels: Andersen and 6'4" Ram
 > Andersen and 6'4" Ram
Page of 5
richclover
WY
Posted: 09/15/20 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
“...With the popularity of the Andersen , that is not a bad idea if someone actually has the Andersen hitch, odds say they won't ,they will steal a fifth wheel with a convention pin box , having a convention fifth wheel hitch to do the stealing with ...”
Agreed. The lock does makes it nearly impossible for the adapter to “walk away”. I also remove the ball from the top of my hitch and lock it in the toolbox when not in use.
Rich
2018 Ram 4X4 2500HD Cummins
2020 Chaparral 336TSIK
2019 RAM 1500 Classic 4X4 Hemi
2019 CanAm Maverick Sport 1000
SW WY
Durb
NW
Posted: 09/15/20 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
OP, back on topic. I talked with a man at a campground a couple of years ago with a new, high end, Ram and a new Montana High Country trailer. He wasn't too happy, his cab was dented and his rear window was gone and taped over with plastic. His Andersen hitch in the rear position was allowing his pin box to bite chunks out of his tailgate so he reversed the adapter. He happily towed for many miles until he lost focus on a tight back up combined with a driveway dip. The Montana does indeed have rounded corners but the trailer slopes forward from the overhang. When he went into the driveway dip the trailer leaned forward and took out his window. His dented cab was near the roof. You may want to keep this in mind.
Look at the Blue Ox Super Ride instead. It will hinge rearward when you need it.
cummins2014
Utah
Posted: 09/16/20 07:33am Link  |  Quote  |  Print  |  Notify Moderator
I agree, if you blindly back up ,and not pay attention you are going to get into trouble. That was my concern with the pinbox being to close to the tailgate . If I would have had time on that first tow with the new fifth wheel I would of trimmed the corners on the pinbox , instead as said I reversed the adapter. I have no issues with it reversed . The combination of the pinbox placement on the fifth wheel ,and the rounded corners I don't plan on reversing it or doing anything with the pinbox .
I too have a driveway with a dip , and a street that is a bit too narrow to be able to back in gradual . I have to crank it pretty tight ,but still not a problem.
cummins2014
Utah
Posted: 09/16/20 07:41am Link  |  Quote  |  Print  |  Notify Moderator
When I am not towing the tonneau cover is hiding the hitch, although if they want it ,they will get it, but with a locked tailgate they will have to cut the tonneau cover out of the way or break open the tailgate. It won't be easy.
As far as the adapter, I suppose someone will steal anything , but I can't imagine those adapter being in high demand. Taking the time ,and having the allen wrench ,and wrenches to remove just doesn't sound likely. I think that lock is mostly to prevent the theft of the fifth wheel, and here again I like my odds they don't have an Andersen hitch .
Cummins12V98
on the road
Posted: 09/16/20 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Long bed truck solves all the worlds problems!!!
For your viewing pleasure. Heck there is even room for a 30" front to back bed height tool box.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
JIMNLIN
Oklahoma
Posted: 09/16/20 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Good points.
Where the hitch was located in the bed ...
how the back of the pin box was shaped...
length of the pin box...
pin box location
...are all unknowns.
Apparently most Andersen users as you don't have these issue.
* This post was edited 09/16/20 05:53pm by an administrator/moderator *
cummins2014
Utah
Posted: 09/16/20 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
JIMNLIN wrote:
Good points.
pin box location
Its usually just the ones that are not paying attention ,and takes out a back window or dent their cab are the ones with the issue of their own doing.
This Andersen does give you more clearance than a conventional hitch or a manual slider. Of course a manual slider does, when used ,but how many times have we read where they took out their window or dented the cab because they didn't use the slider. Its not the hitch at fault here .
The hijacker did take longer then usual . [emoticon]
* This post was last edited 09/17/20 05:41pm by an administrator/moderator *   View edit history
richclover
WY
Posted: 09/16/20 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed again, however, having had a theft or two, I feel better knowing the "house" and related "stuff" will be there when I get back. Perceived security is worth it. To me.
As for the "hijacker" I'll bet he can't get that big heavy hitch out of his truck bed and re-installed in 15 minutes. I can. Tools/equipment required is, as you know, a torque wrench. One of the reasons I bought an AUH. I've got a short bed with tool box and I can use it easily.
ford truck guy
Pennsylvania
Posted: 09/16/20 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same hitch but the 20k version.... 153# ... 2 slip pins to remove the head at 75#... 4 slip pins to un hook the lower portion 78#... possibly 10-15 minutes total IF I have a beer in between removing the top and bottom portions
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Cummins12V98
on the road
Posted: 09/16/20 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
"As for the "hijacker" I'll bet he can't get that big heavy hitch out of his truck bed and re-installed in 15 minutes."
Well let's assume I am the so called "hijacker". I don't need a torque wrench to install mine. I can have mine removed or installed in 5 minutes MAX. Could be faster but I just turned 63.
Page of 5
