RV.Net Open Roads Forum: Tech Issues: Deep cycle battery maintenance
 > Deep cycle battery maintenance
naturist
Lynchburg, VA
Posted: 09/14/20 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Don’t need a watering system. Those are for helpful for folks with multiple batteries in a hard-to-reach place. Waste of money for us mortals with one easy to reach battery.
Don’t sweat it. If you check the water frequently you are good.
KD4UPL
Swoope, VA
Posted: 09/14/20 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Just keeping the water above the plates is a dangerous gamble. If those plates ever see air it will ruin a battery in a hurry. As has been stated, the water needs to be at the bottom of the fill tube. This allows a bit a reserve. I suspect your batteries need water to achieve this level.
Wherever I happen to park
Posted: 09/15/20 04:54am Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
Add distilled water until it just reaches the bottom of the fill tube. Do not fill to the top of the case/cap. This allows for a adequate reserve and for the battery to vent.
You can buy a battery filler bottle that will fill them to the correct level.
Uh that is overfilling you stop 1/4 to 1/8" BELOW the bottom of the fill tube.. You have to give it "Breathing room".
If you dig enough you will find that on the better battery sites.
I grew up when flooded wet cells were all there were. The first Maintenance free were.. Just Coming out. and that is what they taught back when everybody used them.. Alas they forgot that with the modern maintenance free, which of course are nothing of the sort.
Home is where I park it.
2112
Posted: 09/15/20 05:38am Link  |  Quote  |  Print  |  Notify Moderator
Fill per information provided on #6
Equalize at least once per year per #10
#12 will tell you the general health of your batteries. Check them with a hydrometer a few times a year and equalize if needed
#14 and 15 is good info. Fully charge as soon as possible
Mine is plugged in 24/7 and my junk converter/charger holds a constant 13.6V, which is too high for float charge. I put a timer on my battery that allows it to charge 2 hours every 5 days just to keep it topped off.
2013 KZ Durango 2857
StirCrazy
Kamloops, BC, Canada
Posted: 09/15/20 07:51am Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
For MAXIMUM battery life, I believe that lead acid batteries should NOT be on a charger 24/7 ! 4 - 6 hours per day on a "maintainer" is plenty.
shoot, some one forgot to tell my batteries that. they have been plugged in for the last 14 years and are just starting to show there age this year..
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
BFL13
Victoria, BC
Posted: 09/15/20 10:03am Link  |  Quote  |  Print  |  Notify Moderator
If you do get to where the water is low but plates still covered and do a really big refill, how long before the SG ever comes out right again? Say you don't do a deep cycle but just a few hours of high voltage--which doesn't do much for the SG, then go on a 13.8v float.
Days, weeks?
Or do you have to do a deep cycle or two?
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 09/16/20 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Jeezo
Try constant voltage after max specific gravity that has been reached of about 600ma per 100 amp hours at 20c
wnjj
Cornelius, Oregon
Posted: 09/16/20 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Our camper has a single group 29 battery and a PD9245 charger. It has been plugged in every minute since 2006 that it wasn't on camp trips. The cheapo Interstate battery lasts at least 6 years before noticing a little loss of performance. I have never once added a drop of water. I quit checking when it was never low.
For our setup/use, "maintenance" is pretty much nothing.
Veebyes
Posted: 09/17/20 10:48am Link  |  Quote  |  Print  |  Notify Moderator
There is no need to keep a battery on trickle charge 24/7. If the trailer is 12V 'dead', no parasitic drains, the battery will hold charge for months without attention. Just be sure it is put into hibernation fully charged & watered.
Think about it. Farmers & construction companies leave machinery untouched for months at a time in the harshest of conditions. Doubt if they think about the well being of batteries anywhere near as much as the average RVer.
2007 Alpenlite 34RLR
MEXICOWANDERER
Posted: 09/17/20 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
LOVE IT
Made a lot of money off that philosophy
