RV.Net Open Roads Forum: Class A Motorhomes: smoking diesel exhaust
 > smoking diesel exhaust
joelc
Cedar Point, NC
Posted: 09/15/20 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Looked up black smoke from diesel on internet and results said over-fueling. Fuel injector wear. Check it out on the net for your model.
wolfe10
Posted: 09/15/20 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Sure. OR, "under airing". Either/both lead to an over-rich mixture.
And, a lot of over-fueling is done on purpose for those who want more HP and aren't concerned what they/others breath.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
warrenjo46
Matthews, NC
Posted: 09/15/20 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
JRscooby wrote:
mike brez wrote:
Just cause it smokes don’t mean it’s broke[emoticon]
That pickup should be impounded, sold at auction to somebody that agrees to repair it before use. The owner should be fined to the point he and his family are living in a grocery cart.
I could not agree more. How come do diesel pickup drivers think they can delete their engines and ignore the laws the rest of us should obey.
JRscooby
Indepmo
Posted: 09/16/20 04:24am Link  |  Quote  |  Print  |  Notify Moderator
When I first started hauling a old hand told me "Put on what you want to haul, but never go over unless you can step with it" Back then you where much more likely to get caught with a overload if you where the slowest truck. We would put more fuel until we would get a light smoke WFO and under load. Heavy smoke, like in the pic, the engine was lugging.
The drive by wire engines don't need to put out heavy smoke,
joelc
Cedar Point, NC
Posted: 09/16/20 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
The guy is asking a legitimate question and wants to solve a problem. No need to penalize him. I am sure many of you have asked questions before that are common sense to others, but not you. Give they fellow RVer a break.
wolfe10
Posted: 09/16/20 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of good "what to check" posts here. Many of them FREE to anyone who cares to check.
Checking air flow and fuel filters is NOT rocket science.
Mr.Mark
Out West and Mid South
Posted: 09/16/20 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
down home wrote:
Our Cat has always done itit'saC7 and when you hit the throttle in goes more fuel.
A diesel does not mix fuel and air and go through throttle blades. It breathe in as much air as it can handle all the time. Hit the throttle and lot more fuel and black smoke. Newer diesels don't have the response of the old because emissions dictated tuning. The Volvo engines are a good/worse example. Low and slow response and power throughout the range and mileage is worse and have lots of engie fires.. Tuners spew more at take off and hot rod diesel engines rely spew the smoke as cam and injector timing is increased and more fuel is sprayed in when you hit the throttle and really gets going when the turbo(s)spool up.
When injector pumps go bad in diesels you will smell and possibly see gray smoke actually raw diesel and smell and raw diesel though the exhaust.
haven't seen in my case any MHs spewing a lot of black smoke even with a tuner.
The turbo could be getting bad...and not compressing enough air for the amount f fuel sprayed in would be the only thing I can think of at the moment.
Hard to hear in a running diesel but a stethascope on the turbo might reveal bearing problems etc. Not cheap but what s on a diesel,a Cummins Dealer or other shop hooked up to the computer, unless yours is pure mechanical diesel, can sort it out pretty quick.I don't think I want to crawl around on our engine and side radiators probably still would have to go through the bed room.A Diesel mechanic knows his brad and others real well.
"The Volvo engines are a good/worse example. Low and slow response and power throughout the range and mileage is worse and have lots of engie fires.."
Having a Volvo engine I have never heard of what you have stated. Engine fires?
We have amazing power at 56,000 lbs. I have not heard anything negative at the Prevost centers about the Volvo engine. Did I misunderstand your post?
Safe travels,
Mark
Mr.Mark
2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo w/1,750 lb. ft. of torque, 1.5 baths, 4 slides.
2017 Lincoln MKX AWD V6 335 hp twin turbo.
down home
south
Posted: 09/17/20 12:03am Link  |  Quote  |  Print  |  Notify Moderator
We've seen three newer Prevost passenger coaches with engine fires, I don't know the years of the coaches but were newer. That doesn't mean much.
However at a Michigan RV Resort last year or year before, We sat and talked with some Folks in two Prevost coach conversions and another brand, I don't remember. One was a Marathon Coach and another brand Conversation, was about the weak take off the 515 hp Volvo and response down the road. The 650 hp, I think, Cummins engines was being requested by some of the new Customers, plus reports of fires. It was mentioned it was probably the pollution control systems now required on everything.
* This post was edited 09/17/20 12:14am by down home *
Mr.Mark
Posted: 09/17/20 05:58am Link  |  Quote  |  Print  |  Notify Moderator
Down home.... from personal experience I don't believe the power of the Volvo engine is inadequate. Certainly a fire can happen as there are a lot of components that could fail as with any coach. Newer Prevosts have a built-in fire suppression system in the engine compartment with a warning and controller at the driver area.
The Volvo engine has 500 hp with 1,750 lb. ft of torque, not too shabby! The Detroit Diesel has 515-525 hp with 1,650 lb. ft. of torque.
You cannot upgrade the engine in a Prevost. There is not enough room for a larger engine.
Sounds like 'fire-side' chat.
Safe travels,
Mark
