RV.Net Open Roads Forum: Class A Motorhomes: Noisey seat coushions
 > Noisey seat coushions
Jay58
Melbourne (central east coast) Florida
Posted: 09/14/20 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
The theatre seats squeak/ scree h as operated.
Who has a solution other than " dont do that"?
2020 Jayco Precept 34G
Central Florida (East Coast)
Tom/Barb
Oak Harbor, Wa
Posted: 09/14/20 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
They are called Whoopy cushion [emoticon]
down home
south
Posted: 09/15/20 05:31am Link  |  Quote  |  Print  |  Notify Moderator
DrewE
Vermont
Posted: 09/15/20 08:52am Link  |  Quote  |  Print  |  Notify Moderator
By "operated", do you mean when reclined or otherwise repositioned, as opposed to simply when someone is squirming while seated?
If so, the noise must be coming from the adjustment mechanism somewhere, and presumably could be eliminated by proper lubrication or adjustment or rebuilding with better bearings/pivots or something along those lines. Personally, I'd just live with it, since fixing seems like it's probably a lot of effort with disassembly and analysis and so forth.
Jay58
Posted: 09/15/20 10:09am Link  |  Quote  |  Print  |  Notify Moderator
When reclining or sitting up it is the fabric rubbing...what can be done to silence the rub...its not the frame mechanism
352
Oxfofd, Fl
Posted: 09/15/20 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
Your kidding right? I wish everyone out there had these minimal issues. Put on some axel grease where it squeaks.
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
chuckftboy
Fleming Island, Florida
Posted: 09/15/20 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Shy of replacement furniture, probably not much you can do.
2019 Horizon 42Q Maxim Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
Jay58
Posted: 09/15/20 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
My minimal problem is it is in a 2020 class a
