RV.Net Open Roads Forum: Towing: Need hitch advice please.
Search only in Towing
Open Roads Forum  >  Towing
 > Need hitch advice please.
BarneyS
S.E. Lower Michigan
Posted: 09/15/20 08:19am Link  |  Quote  |  Print  |  Notify Moderator
In your photos of your setup, you have THREE components pictured.
1. The shank - that portion that inserts into the trucks receiver. In your case you have a double shank, possibly homemade. TorkLift also makes one very similar. You need one as shown by Mitch150.
2. Another shank - the portion that the hitch head bolts onto. This is the only shank part you need, only you need to get one with the proper drop to level your trailer.
3. The hitch head - the part that bolts onto the shank with two large bolts (usually torqued to around 260ft/lbs or so) and which the ball mounts onto.
What this whole thing amounts to is that you need to purchase a new shank with the proper drop to level your trailer, mount your hitch head on it in the proper position to level your trailer, install the ball and then attach the trailer and go camping! [emoticon]
Unless you have need for a multiple shank mount to carry a bike or other item while towing your trailer, I would sell or otherwise dispose of that shank you have now.
Barney
Not towing now.
Kelpike
Agawam mass
Posted: 09/15/20 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Sjm9911 wrote:
Im not understanding this whole thing. You can take the extention bar thing off and put the wdh on normally. Or if the wdh can be put in upside down( mine can) then unbolt it and move it up to get less drop. What am i missing here?
I have the right height with the adapter. I don't get enough drop without the adapter no matter which way I put my wdh. I need to eliminate the adapter which means I have to buy a longer drop shank. I'm not sure if all drop shanks are universal in the spacing of the holes. Mine now are 1 1/4" apart.
Posted: 09/15/20 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
If you don’t want to use your home made adapter, don’t have enough drop with the adjustable height hitch head plugged in direct to receiver and can’t get the trailer level enough with the drop shank you have, then yes you need a longer drop shank.
