RV.Net Open Roads Forum: Travel Trailers: TPMS
Raife
Posted: 09/15/20 08:45am Link  |  Quote  |  Print  |  Notify Moderator
So we are new owners of an Grand design Imagine XLS 21BHE. I would like to get a TPMS, but want a small footprint in the cab. I am thinking of the TireMinder Trailer TPMS (https://www.tireminder.com/products/tire........nitoring-systems/tireminder-trailer-tpms), but it lists the PSI range up to 70 PSI. My tires are 65 PSI...Is this too close to the upper limit?
I was also thinking of the TireMinder Smart TPMS (https://www.tireminder.com/products/tire........monitoring-systems/tireminder-smart-tpms). The PSI range is much better (up to 232PSI), but I like the dedicated display of the Trailer one.
There is also the topic of cost (Trailer - $146 and Smart - $356)
Thoughts?
Thank you.
dodge guy
Bartlett IL
Posted: 09/15/20 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Cant help with those. I have a TST system with the color monitor. The monitor is mall and should take up less room than a phone or GPS.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Bobbo
Wherever I park
Posted: 09/15/20 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
Second the TST
Bobbo and Lin
Rover_Bill
NE. Ohio
Posted: 09/15/20 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
Perhaps the OP should go back to the TireMinder website and review both product descriptions. BOTH versions ( Trailer and Smart) monitor tire pressure up to 232 psi. for 22 tires.
Raife
Posted: 09/15/20 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
I did review the TireMinder website and the first line of the Trailer TPMS states:
"The new TireMinder Trailer TPMS is TireMinder's newest Tire Pressure Monitoring System, designed specifically for dual or single axle trailers running 70 PSI or less." (my bold added)
For some reason the link is not working in my original post, but it is this system...
https://www.tireminder.com/products/tire-pressure-monitoring-systems/tireminder-trailer-tpms
Here is the correct link for Smart system (which does go to 232PSI as I stated):
https://www.tireminder.com/products/tire-pressure-monitoring-systems/tireminder-smart-tpms
Thank you.
* This post was edited 09/15/20 10:52pm by Raife *
archbarb
SE Georgia/Middle Tennessee
Posted: 09/16/20 07:03am Link  |  Quote  |  Print  |  Notify Moderator
TAT system here also.
GrandpaKip
Flat Rock
Posted: 09/16/20 07:51am Link  |  Quote  |  Print  |  Notify Moderator
I’ve had the Trailer version for about 3 years now and it has worked well with both 50psi and 65psi tires. It does have a limit of 70 psi, but I’ve never had a problem with that.
It does read about 3 to 4 psi lower than my air pressure gauges do.
My son has 65 psi tires and the same system. No problems, either.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Rover_Bill
NE. Ohio
Posted: 09/16/20 11:46pm Link  |  Quote  |  Print  |  Notify Moderator
AAAH! Comparing apples to oranges. [emoticon]
The Smart TPMS (Clicky) that you are referring to is a cell phone enabled deluxe version of the standard RV TPMS - TireMinder Model TM-77 (Clicky). Twenty-two tires, up to 232 psi., with repeater for standard long trailers (>30 ft.)
The Trailer TPMS (Clicky) that you are referring to is the new SOLAR POWERED TPMS designed for smaller (pop-up/utility/mini) trailers less than 25 ft long, not more than 4 tires, and not more than 70 psi. per tire. (TPMS warranty is void if the tires exceed 71 psi).
Sorry, I assumed that you were comparing the Smart unit with the standard RV trailer unit TM-77. I use and recommend the TM-77.
2015 GMC Canyon 3.6L V6 4X4 TowHaul SLE ExtCab Bronze
2016 Keystone Passport GT 2670BH
ReCurve R6 hitch, DirecLink brake controller
2005 Suzuki C50 2006 Suzuki S40
JIMNLIN
Oklahoma
Posted: 09/17/20 06:23am Link  |  Quote  |  Print  |  Notify Moderator
I've ran D tires on smaller equipment/cargo trailer carrying close to max axle loads and on hot 100+ temp days psi went to the 72-75 ranges. Sound like you need a real TPM system for full size trailers.
