RV.Net Open Roads Forum: Class C Motorhomes: Gravity Water Fill
 > Gravity Water Fill
dunl1492
Home
Posted: 09/15/20 11:54am Link  |  Quote  |  Print  |  Notify Moderator
Is there a way to fill the water tank of a Coachman Class C without "city" water under pressure? I will be visiting a CG without "city" water connections, but they do have a potable water hose, just no hardware to connect it to my inlet water port. Trying to use the potable water hose to fill my tank using just gravity. Any help would be great.
IDman
Oklahoma
Posted: 09/15/20 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
The manufacturer did you a big favor by not putting a gravity fill on your mode. It "saved" you $7.29 or so! It's a good example of how they scimp and delete things we take for granted.
valhalla360
No paticular place.
Posted: 09/15/20 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
I assume you looked around on the exterior and didn't find a fill hole?
If you don't: You could stop by the hardware store and pick up a garden hose end fitting. It would only take a minute or two to put it on, fill up and then 30 seconds to pull it off. Just have the fitting and a screwdriver handy by the front seat when you pull in.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
jdc1
Rescue, Ca
Posted: 09/15/20 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
I think he needs a "Water thief".
https://www.amazon.com/Camco-Connects-Standard-Various-Sources/dp/B000EDOSKG/ref=sr_1_1?crid=3L6G2U4160R8N&dchild=1&keywords=water+thief+faucet+adapter&qid=1600194863&sprefix=water+thief%2Caps%2C288&sr=8-1
rlw999
Washington State
Posted: 09/15/20 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Coachmen as well, and wanted to be able to fill my tank from some 5 gallon jugs. I thought I could just hook up a short hose and use a funnel to fill it through the freshwater fill, but there's a backflow prevention valve or something there that prevents it from filling unless the water is under pressure.
So I bought an RV freshwater pump, attached hose fittings and wired it to my batteries, and used that to pump water from the bottles into the freshwater tank. I keep the pump around as a spare in case the one in the RV fails.
If the hose you're filling from has good pressure, you might be able to use something like a water bandit to slip over the water source hose.
DrewE
Vermont
Posted: 09/15/20 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a winterize setting, to pump antifreeze from a bottle, you can use that to pump water from a container into the tank. It's not the fastest operation ever. Just set the valves for winterization and open the fill valve and turn on the pump.
coolmom42
Middle Tennessee
Posted: 09/16/20 12:26am Link  |  Quote  |  Print  |  Notify Moderator
Seems to me if this were correct, a person would have to fill the water tank with antifreeze, in the process of winterizing.
There is normally a check valve on the tank side of the pump to keep water/antifreeze from flowing backwards into the tank.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
Gjac
Milford, CT
Posted: 09/16/20 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Mine does not have a gravity fill either so I just use one of my over flow tubes from the FW tank to add water using my solar shower bag.
DrewE
Vermont
Posted: 09/16/20 08:51am Link  |  Quote  |  Print  |  Notify Moderator
The fill valve connects the pressure side of the water system (after the pump) to the tank, allowing city water to flow into the tank. When closed, the check valve in the pump prevents this flow, as you note. For normal winterization, the fill valve is not kept open, and the tank does not fill with antifreeze. (It probably would be a good idea to briefly open it to force any water in the fill line out, and thus get a very small amount of antifreeze in the tank.)
Gjac
Milford, CT
Posted: 09/16/20 08:52am Link  |  Quote  |  Print  |  Notify Moderator
How do you by pass the check valve to allow water to flow in?
