RV.Net Open Roads Forum: 2014 Keystone - Montana 3100RL -- Chev 2500HD Diesel
 > 2014 Keystone - Montana 3100RL -- Chev 2500HD Diesel
TenOC
On the road -- Full time
Posted: 09/15/20 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
I am trying to understand how heavy a 5th wheel my truck can tow. The truck is a 2016 Chev 2500HD Duramax 6.6L Turbo-Diesel V8. One web site said only tow a 13,900 lb 5th wheel other website said ability to tow 15,400 ??????
The 5th wheel a 2014 Keystone - Montana 3100RL specs read.
Dry Weight 11,573 lbs.
Payload Capacity 3,027 lbs.
GVWR 14,600 lbs.
Hitch Weight 2,355 lbs.
Can I safely tow??????
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
Roger10378
Goodrich, MI.
Posted: 09/15/20 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
Look at the sticker on the drivers side door of your truck. It will give you the weights for your truck not the averages. Now for the trailer you can normally figure around 22% of GVWR for pin weight that gives you a fully loaded pin weight of about 3350. The sticker on the door also gives you the cargo weight. That includes the weight of passengers, hitch, trailer pin, and anything else you might put in the truck. You do the numbers.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
ford truck guy
Pennsylvania
Posted: 09/15/20 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
your limiting factor will be the PIN WEIGHT.... The amount of weight you can legally carry in the bed compared to the pounds you can legally tow behind you. like stated, check the sticker on your pillar/door jamb to see what the payload is
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
azdryheat
Tucson, AZ
Posted: 09/15/20 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
Legally carry? Weight police don't care about RV's
To the OP, my first towing truck was your make and model in 2009. My 5th wheel was the same weight as yours and I never had an issue towing all over the country. Have fun.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
MFL
Midwest
Posted: 09/15/20 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
IMO the lower tow weight of 13,900 would be about max. You need to weigh the truck loaded to camp, gear, people, full fuel, anything going in the truck. Now get separate axle weights, most all pin wt goes on rear axle. If rear axle weighs 3,200 on scale, and RAWR is 6,200, you can only add 3K more to the rear axle. If you don't have a hitch installed most are about 200 lbs right over the axle. If needed suspension support can be added, such as air bags, or Timbrins. You cannot go over the max tire rating!
Jerry
riltri
Lansing
Posted: 09/15/20 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
Can the truck tow it....Yes. Will you be over weight....yes. Will you be able to tow safely....technically no, but unfortunately others do it all the time.
If you want to tow responsibly, then the answer to your question is probably no. Just my opinion.
TXiceman
Full Time RVer
Posted: 09/16/20 08:37am Link  |  Quote  |  Print  |  Notify Moderator
First off, you loaded pin weight will be closer to 2900# than the dry 2300# from the brochure data.
The tow ratings on the website are manure in my opinion. The numbers they list are based on a stripped model truck and a 150# driver. You need to work the specific numbers up for your truck.
First look for the yellow sticker on the drivers door jamb. There will be a paylaod rating for your truck. This is the most load you can add to the truck bed and passengers.
Use 20 to 22% of the trailer GVWR for an estimated loaded pin weight. Now add the estimate pin weight plus a hitch plus cargo in the bed plus passengers. This total has to be less than the payload capacity sticker.
Adding air bags is a crutch and does not increase towing or load ratings or safety.
A 3/4 ton truck will reach its payload capacity before you reach the maximum towing capacity.
Ken
Amateur Radio Operator.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 09/16/20 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Just to give you an example, our Redwood left the Factory at a 1000 Lbs heavier than the listed Dry in the Brochure. I have no idea how they come up with the numbers they put in those Brochures, maybe a random number generator.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
MFL
Midwest
Posted: 09/16/20 09:56am Link  |  Quote  |  Print  |  Notify Moderator
TXiceman wrote:
"Adding air bags is a crutch and does not increase towing or load ratings or safety."
Wrong...safety/capability YES!
Does not change stickers! Correct
Read my, and Marty's posts over on tow vehicles, on page 3 of the thread New tow vehicle.
Jerry
riltri
Lansing
Posted: 09/16/20 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Jerry
Perhaps I am not understanding what you are saying but airbags do NOT increase capacity. They will help level your load and increase stability, but it will not change your vehicle GWVR
