RV.Net Open Roads Forum: Fifth-Wheels: Half ton towing
 > Half ton towing
Mike134
Elgin
Posted: 09/16/20 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Some do it safely A F150 can be bought with a heavy duty payload package which gives you about 2800 lbs of payload. That's more payload than a F250 diesel. Just need to do your homework.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
TXiceman
Full Time RVer
Posted: 09/16/20 08:26am Link  |  Quote  |  Print  |  Notify Moderator
First thing is to forget the dry weights. Use the trailer GVWR from the tag on the left front of the trailer. This is the maximum weight of the loaded trailer. To estimate your loaded pin weight take 20 to 22% of the trailer GVWR.
Now look on the drivers door jamb for a yellow sticker that provides the payload capacity of the truck. Take your estimated pin weight plus a hitch plus passengers plus any cargo in the truck bed. All of that added up needs to be less then the payload capacity of the truck.
A 1/2 ton truck will reach its payload capacity long before you reach the trucks maximum towing capacity.
Good luck.
Ken
Amateur Radio Operator.
valhalla360
No paticular place.
Posted: 09/16/20 10:36am Link  |  Quote  |  Print  |  Notify Moderator
JIMNLIN wrote:
jeeper....Straight answer would be if your F150 has enough rawr. A 7k dry weight which grows to 8500 lbs, maybe more, = 1600-1800 lb pin weight. Add 200 lbs for hitch/rails/etc......the truck has maybe 2000 lb siting on the rear axle. Now load the cab with all the people and other gear.
This.
Add in 400-800 for people and gear in the truck and I'm betting you are overloaded by the time you head out.
I would want to stay under 7k FULLY LOADED if you are insistent on using a 1/2 ton truck.
Assuming the setup is within weight ratings and properly set up, I wouldn't expect a significant safety difference between 5th wheel and bumper pull. A properly set up bumper pull is not dangerous.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Cummins12V98
on the road
Posted: 09/16/20 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
Bottom line you need side wall stability on any tow rig!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
philh
Belleville MI
Posted: 09/19/20 07:29am Link  |  Quote  |  Print  |  Notify Moderator
I followed a F150 towing what I would guess to be a 30' 5th wheel. I forgot to get the name of the 5er. The truck was definitely squatting, and best way to describe it, wallowing.
I know when I went to 10 ply tires on my F150, towing my TT was much improved.
Curly2001
Tucson, Arizona
Posted: 09/19/20 09:42am Link  |  Quote  |  Print  |  Notify Moderator
My neighbor has a Ford F150 with the ecoboost engine and pulls a Cougar 29' fifth wheel with it. The truck has the heavy duty payload package along with LT tires in lieu of the P-metric tires. He said it also has heavy duty brakes compared to the standard truck. Pulls and stops the trailer very well, according to him. I have seen him on some hills when we camped together and he has no problem keeping up with traffic. Seems to have good stopping power also. I wouldn't want to do it but he has no issues, as of yet.
Curly
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
jeeperman
florida
Posted: 09/20/20 09:33am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the thoughts and opinions, after more consideration I will stick
To my TT and f 150. The ride when not towing is hard to give up as well as the
Cargo room without the hitch in the bed. Happy camping everyone.
 > Half ton towing
