RV.Net Open Roads Forum: Dinghy Towing: Idle Jeep Wrangler while towing?
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  General Topics
 > Idle Jeep Wrangler while towing?
ezgoin
Sunny Arizona
Posted: 09/16/20 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Morning everyone,
I have a question? Is it OK to let a Jeep Wrangler idle while hooked up to MH for towing?
The reason I asked is my battery was dead after towing for 2 days. Fuses checked out OK so not sure if issue was new install of Stay-in-Play brake system or if battery was just old (5 yrs old). I had to replace battery and I don’t want to buy another new battery when I drive back 2 days (if the problem is brake controller).
So i thought I’d see about idling while at rest stops on the way home as a precaution.
Thanks
Ezgoin
The older I get....the better I was.
Bill & Terry
And our canine kids, Skippy & Peanut
2014 Fleetwood Bounder Classic 30T
2016 Jeep Wrangler Unlimited Toad
dodge guy
Bartlett IL
Posted: 09/16/20 11:20am Link  |  Quote  |  Print  |  Notify Moderator
No need for all that excessive idle time. 5 years is max for a wet cell battery. As long as there is nothing on there should be no draw. You don’t leave the key on while towing do you? There is no column lock so leaving the key on isn’t necessary.
You could always run a charge wire from the MH 7-way to the vehicle connector and then to the battery.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
jdc1
Rescue, Ca
Posted: 09/16/20 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Arizona? 5 year battery life is GREAT for Arizona. 120* heat KILLS batteries. Time for a trip to Costco or Sam's Club to buy a new battery.
time2roll
Posted: 09/16/20 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a charge line from the RV? Get your voltmeter out and check that voltage is getting to the Jeep battery.
675w Solar pictures back up
BruceMc
Oregon - Willamette Valley
Posted: 09/16/20 11:31am Link  |  Quote  |  Print  |  Notify Moderator
The Stay-in-play does draw power from the toad's battery. Barring a dying battery (which is entirely possible), the question is: Are you getting power on your charge line from the MH to the toad?
If you are having issues keeping the battery up, then I'd say yes - idle the jeep while at rest stops, just to top it up. As I stated - the Stay-in-play does use the toad's battery, so if the battery is dying/dead, then you'll have little to no supplemental brakes.
It certainly is a good idea to put a new battery in the jeep anyway.
'16 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
Previously:
'00 Four Winds 26Q Class C (Ford E350 V10)
'96 Kit Sportsmaster 212f Fifth Wheel/'93 GMC Sierra K2500
'91 SunLite poptop truck camper
and the first: a Wildernest flip-top canopy.
Horsedoc
Dixie --- N. Georgia
Posted: 09/16/20 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know if it is recommended or not but I do know that I accidently left ours running all the way from Hiawassee, Ga to Athens, Ga. Got interrupted by some long winded guy as we were getting ready to leave and just forgot it. With the engine running for a couple or three hours I was worried but nothing noticeable found. The Brake buddy sure did stop quick several times. Lucky I had put the transfer case in neutral I guess.
sch911
Rochester Hills, MI
Posted: 09/16/20 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
Put in a charge line from the MH. You shouldn't have to run it at all with that installed.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2007 Jeep Grand Cherokee Limited Toad
rexlion
Broken Arrow OK
Posted: 09/16/20 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
Use a voltmeter to check your Jeep’s voltage at each stop for at least the first day. That should tell you if it is being drained enough to matter. If not, don’t worry about idling it.
I have a meter that plugs into the cigarette lighter. Easier than raising the hood.
Mike G.
--for now, using a cargo trailer for camping--
Those who would give up essential liberty, to purchase a little temporary safety, deserve neither liberty nor safety. --Benjamin Franklin
photo: Yosemite Valley view from Taft Point
near Jawbone Canyon, CA
Posted: 09/16/20 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
Five years on a car battery is excellent! Buy a new battery.
wildtoad
Blythewood, SC
Posted: 09/16/20 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
Look into changing your braking system so you don’t need any power at the Jeep while towing. We can remove the key to the Jeep, thus no power drain at all.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
