RV.Net Open Roads Forum: Bad air quality--finally taped a house filter on the A/C
 > Bad air quality--finally taped a house filter on the A/C
wopachop
lb
Posted: 09/16/20 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Its the cheap kind ive had it for years. Hope its decent for smoke particles. What are the negatives besides tape residue and reminding me of wearing a mask? Im out of blue tape. Just got to the trailer and decided to slap it up real quick. Made it a partial dome shape. It was holding up without the tape. Which i consider a bad sign. But i suppose the stock filter does as well.
I do have 2 larger pieces of filter if the A/C pros consider it too restrictive. My plan years ago was to make a nice looking filter housing so i could leave it installed. I dont want to leave the tape overnight.
Safe to assume running the fan on low would be best? Or could that act like bogging down an engine? I know we are talking about an electric motor. Its more comparing a bogged down engine to the efficiency of the fan blades. Maybe the fan blades work better at the higher speed. For now i have it manually set to stay on low.
wildtoad
Blythewood, SC
Posted: 09/16/20 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
What are you trying to solve with this rather ugly DIY filter? Clean the original filter and coils.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
wopachop
lb
Posted: 09/16/20 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
I agree it sure be ugly.
profdant139
Posted: 09/16/20 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
wildtoad, it may look funny. But if you were stuck in a place with bad smoke (West Coast), this solution is a lot better than nothing.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
time2roll
Posted: 09/16/20 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
You really need MERV-11 or better to block smoke particles.
Might get some with that but it will take a large format filter to minimize restriction.
675w Solar pictures back up
Flyfasteddie
Idaho
Posted: 09/16/20 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
Wildtoad, he's trying to mitigate the horrific air quality those of us in the west have been under for the last week. Wopachop, if I was out in the RV in this mess I would do the same thing. I would just go by the sound of the motor - if it's bogging too much then try something less restrictive. It's going to be a trade off, the more restriction the more potential stress on the motor but I would be trying to filter this lousy excuse for air too.
Old-Biscuit
Verde Valley
Posted: 09/16/20 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
Is that on the Return side?
YES...then you will end up with diminished return airflow which can lead to Evap Coil Icing up especially with fan speed on low
RV A/C Units are 'recirculating' units...inside air gets sucked in/cooled down/discharged back inside
You source of smoke is via bad slide seals, open roof vents, open windows, entry door leaks etc
It's not from the A/C Unit.
wopachop
lb
Posted: 09/16/20 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Wonder if i could measure intake airflow. I do have a cheap anemometer i could rig in there. Could also mount a small camera. Actually i think i could do it.
Goal would be to test the stock filter. Then see what the new filter does. Ive wanted to run a household filter on the trailer AC for years now. Its dusty here.
The smoke issue was enough to tape the filter up real quick. Will pull it down now before i forget.
Rover_Bill
NE. Ohio
Posted: 09/16/20 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
Most A/C filters (and furnace filters) are for cleaning dust only and don't trap smoke. To clean out smoke you should use a stand-alone air purifier equipped with a HEPA and carbon filters. Something like this.
2015 GMC Canyon 3.6L V6 4X4 TowHaul SLE ExtCab Bronze
2016 Keystone Passport GT 2670BH
ReCurve R6 hitch, DirecLink brake controller
2005 Suzuki C50 2006 Suzuki S40
Old-Biscuit
Verde Valley
Posted: 09/16/20 11:31pm Link  |  Quote  |  Print  |  Notify Moderator
What trailer.....what A/C Unit?
