RV.Net Open Roads Forum: Truck Campers: Black tank welding?
 > Black tank welding?
Kayteg1
California > Nevada
Posted: 09/16/20 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
Need to reshape my black tank and that will require plastic welding.
Anybody has any experience with such job?
What tools are needed?
jimh425
Western MT
Posted: 09/16/20 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
That seems like a really smelly job with a smelly result if the fix fails. Have you thought about just buying another tank?
Seon
Lake Camanche, CA
Posted: 09/16/20 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
jimh425 wrote:
...Have you thought about just buying another tank?
Repairing seems like a (c)rap shoot. Replacing with new is a good idea [emoticon] .
* This post was edited 09/16/20 09:37pm by Seon *
dwrat
Phx, AZ
Posted: 09/16/20 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like he needs to reshape his tank, not a new tank.
Yes there people who can do plastic welding.
time2roll
Posted: 09/16/20 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
Some Plasti-Mend and some sheet ABS should work.
I assume the tank is ABS
675w Solar pictures back up
BobsYourUncle
Calgary Alberta Canada
Posted: 09/16/20 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced a black tank in a rebuild I did years ago, rather than repair the old one.
I went to my local RV parts store armed with the measurements I needed, and the hole locations.
They had a catalogue of generic tanks, with all the specs on them.
I picked the one I wanted, told them where to put the holes, and ordered it.
It fit perfectly.
Dmax/Allison
1997 Triple E Topaz 27' Bunkhouse TT
I do
Precision Guesswork
based on
Vague Assumptions
Unreliable Data of Dubious Accuracy
provided by persons of
Questionable Intellectual Capacity
Now, What would you like done?
Kayteg1
California > Nevada
Posted: 09/16/20 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
New tanks go in the range of $300 and I still would have to DIY the pipe flanges.
I know plastic welding is tricky, but in the past I was very good with welding rods and welding torches, so I am willing to try new trade.
JRscooby
Indepmo
Posted: 09/17/20 04:24am Link  |  Quote  |  Print  |  Notify Moderator
I have not done much of it, but welding plastic is pretty much like welding with a torch. Heat the material until it starts to flow, and flow in the rod. Instead of flame, use a stream of hot air.
I would want to practice on other things made out of same type material before I did the tank.
Seon
Lake Camanche, CA
Posted: 09/17/20 05:40am Link  |  Quote  |  Print  |  Notify Moderator
Years ago I bought an ABS welder from Harbor Freight that I never used.
Is this what you're looking for?
https://www.harborfreight.com/plastic-we........or-and-temperature-adjustment-96712.html
Reality Check
North Bend
Posted: 09/17/20 05:56am Link  |  Quote  |  Print  |  Notify Moderator
It's actually quite easy. Just get the correct 'filler' rod. Even available on Amazon.
'16 F550 CC, 4x4 with Link Ultraride air suspension, '11 AF 1150. Just so we can play with our snowmobiles, dirt bikes and fishing boat. And new 20' tag along...kayaks, bikes, mc's and extra water and food!!
