RV.Net Open Roads Forum: Travel Trailers: FORD F-150 AXLE RATIO CHOICE
 > FORD F-150 AXLE RATIO CHOICE
Page of 6
MitchF150
Puyallup, WA
Posted: 09/17/20 10:36am Link  |  Quote  |  Print  |  Notify Moderator
I'd say get the 3.55 if you plan to tow that size trailer.. With the 10 speed, you can still select the gears accordingly and when running empty, it'll be just fine...
I have 3.73's with the 6 speed and Eco and it's a great combo for everyday driving and towing a #7000 TT.
When towing, I keep it in 5th Keeps me around the 2200 rpm range and the boost lower than towing in 6th.
You will find that running an EcoBoost, you have Eco or Boost.. If you are in the Boost, you will suck the fuel and the engine will run hot...
Towing, you won't get any better mpg's with any gear ratio..
Empty, with my 3.73's going 70 mph, I'm at 2000 rpms and can get 19-20 mpg on the hwy.
I'd get the 3.55's if it was me.. [emoticon]
Good luck! Mitch
dodge guy
Bartlett IL
Posted: 09/17/20 10:38am Link  |  Quote  |  Print  |  Notify Moderator
As I said in the other thread. You will need the 3.55 gears. Just pulling in a lower gear is not the same as opting for a lower gear ratio!
And again, get the max tow and HD Payload.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
wing_zealot
East of the Mississippi
Posted: 09/17/20 10:49am Link  |  Quote  |  Print  |  Notify Moderator
My 3.5 ecoboost w/10 spd transmission and 3.73, gets 15 mpg around town, 21 mpg plus highway and 10 towing, and it's a towing beast. Don't worry about mpg, go for towing guts and go all out and get the 3.73.
valhalla360
No paticular place.
Posted: 09/17/20 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
APT wrote:
Only 6600 pounds dry will be 7200-8000 pounds loaded. Combine that with pulling two sheets of plywood through the air at 65-70mph.
That is a 7% difference in gearing. You'll never notice a measurable difference in fuel consumption. You will feel a 7% difference in wheel torque. I recommend 3.55 (or whatever the highest numerical axle availible).
In the old days of 3 speed transmissions that made a lot of sense because if you dropped down a gear, it felt like you were red-lining the engine to make 55mph.
With lots of gears to choose from, very little impact from the rear axle ratio unless you are pushing beyond what the lower (numerical) ratio is rated for.
The engine doesn't know how it got to the overall gear ratio (transmission plus axle ratio)...it just knows the final gear ratio, so the engine will run at roughly the same RPM & torque for a given speed even if it picks a different transmission gear to do so.
I would select for the highest payload possible.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
jfkmk
NJ
Posted: 09/17/20 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
My 2018 has the 3.55 gears and the 3.5 Max tow. It tows a 6000# like it’s not there, and I still get 22 mpg highway not towing. The Max tow has the 36 gal. fuel tank which is worth it in itself.
snowedin
Poverty Flats, MT
Posted: 09/17/20 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
I have also been looking at the towing options for the 2021 F150 and have in the past gotten the Max Tow Package because it included all the items one wants for towing at a price less than if each item were optioned separately but this year it appears to include 20" wheels and I don't want 20" wheels. Have had the 3.55 gear ratios with my 2014 3.5 Ecoboost and also with the 2017 Ecoboost and definately will get the 3.55 again. My brother and I each had identical 2014 F150's except he had the 3.31 gearing and I had the 3.55, I consistently got better everyday gas mileage (I know that the driver has more to do with gas mileage than maybe the gear ratio does but am just relating my experience). Hopefully I am wrong about the 20" wheels but on Ford's Build and Price website that's what comes up. The Max Tow Package includes the 3.55 gearing as I recall. And for me the 36 gallon gas tank was absolutely essential as you will be getting 10 mpg or less.
* This post was last edited 09/18/20 07:55am by snowedin *   View edit history
APT
SE Michigan
Posted: 09/18/20 07:21am Link  |  Quote  |  Print  |  Notify Moderator
I agree the 10-spd trans (I have a vehicle with 9-spd) makes a huge difference and final drive means less. Axle ratio makes a difference for 6spds in RV owner experiences. But there is no justification for a lower axle ratio. It certainly isn't fuel economy for anything except the US Government fuel rating drive cycle. If you are compromising for something on a lot that you have to get in under a month - maybe.
I also agree payload is more important than axle ratio for this truck. I also recommend getting the largest fuel tank available.
2017 Subaru Outback 3.6R
ppine
Northern Nevada
Posted: 09/18/20 07:34am Link  |  Quote  |  Print  |  Notify Moderator
All of this talk about mileage.
A diesel will out pull your little 3.5, get better mileage and last twice as long. I will retain its value much better.
JRscooby
Indepmo
Posted: 09/18/20 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Everybody is talking about no difference at highway speeds. But the high speed gears will put more strain everything when starting the load.
valhalla360
No paticular place.
Posted: 09/18/20 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Assuming you don't exceed the ratings...it will only put more strain on the drive shaft and rear transaxle gears but they are rated for that extra load.
Everything else will see identical strain levels.
- The axles past the pumpkin have no clue what is providing the torque.
- The transmission will simply select a different gear to keep the strain the same and the engine won't know the difference as the overall gear ratio will be pretty much the same.
It's only if you exceed the max rating for the rear end that it becomes an issue.
Page of 6
