RV.Net Open Roads Forum: Towing: Are truck/trailer rims a weak link?
Search only in Towing
Open Roads Forum  >  Towing
 > Are truck/trailer rims a weak link?
Fstmvrerik
Salina, Ks.
Posted: 09/17/20 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
After reading a lot of information in regard to weights and towing on this forum I was crawling around my F350 srw looking at weight ratings for the various components on my truck. I have 3750 per tire, and 3640 per rim (both aftermarket). My heaviest scale ticket shows 6120 on my drive axle, which is under the 7280 weight rating of my rims: when you think about the pounding that happens driving down the road, how often does the weight exceed the rating of the rims?
I have broken several rear rims and 1 front rim over my lifetime, but I have chalked them up to when I de-bead tires, or rock strikes doing stupid stuff driving to places probably above the trucks paygrade.
Now wondering if highway travel and heavy trailers could be part of the problem. How frequently do rims fail?
carringb
Corvallis, OR
Posted: 09/17/20 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
I cracked 2 rims as well. Both were Alcoa dually wheels, but I was regularly overloading them by about 500 pounds each. No doubt the overweight condition was a factor, but I also travel on a lot of rough terrain.
I wouldn't worry about dynamic loading. That's already factored into the engineered ratings. But I never realized the rating on my Alcoas could be an issue, because the weight rating was inside the rim on the tire side, so I never saw it until I cracked one and had the tire off.
2014 ORV really big trailer
2015 Ford Focus ST
Old-Biscuit
Verde Valley
Posted: 09/17/20 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Other than some serious off-road/rock climbing I have never broken a rim, truck or trailer
Have bent one rock crawling when I slip down but didn't break the tire bead
But then I don't run aluminum rims.....steel only
valhalla360
No paticular place.
Posted: 09/17/20 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
The rating is based on dynamic loading...so they already have you hitting normal bumps.
Now if you hit a curb or rock...or you have a blow out and the rim hits the pavement hard all bets are off but a higher rated rim is unlikely to help.
Just running down the road nothing unusual, I've never heard of a rim failing (not that you should overload them).
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
BenK
SF BayArea
Posted: 09/17/20 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Agree...Dick Cepek taught that with my first purchase from him. Wanted alloy wheels for the dune buggy and called him (he used to advertise in the back of one of the off readers magazines
Then for the 1973 K5 Blazer, ordered the delete back to min stock tires and wheels...drove down there as a breaking and new tires/wheels. He remembered me and we talked about alloys again. Decided on steel after all of his cautionary points described me.
Alloys crack when they struck boulders at slow, crawling speeds. Steel will bend and hammer it back with a ball peen hammer.
-Ben Picture of my rig
ferndaleflyer
everywhere
Posted: 09/17/20 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
I have been driving about 65 years and have cracked 1 aluminum wheel and it was on my Mercedes years ago. Trailers, DP, Cs, Bs, all kinds of cars and trucks rode hard and put away wet----1 wheel hit a deep pot hole!!!
twodownzero
NM
Posted: 09/17/20 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
There's plenty of stuff I spend time worrying about. This isn't it. The wheels are much stronger than the tires around them.
Posted: 09/18/20 12:12am Link  |  Quote  |  Print  |  Notify Moderator
Good to see ya back!
And an unexpected response from the chief of the weight police!
Have you been enlightened?
wing_zealot
East of the Mississippi
Posted: 09/18/20 05:13am Link  |  Quote  |  Print  |  Notify Moderator
That's exactly what I was thinking also, but the OP has already broken 3 (or more). That is beyond an anomaly.
pitch
NY
Posted: 09/18/20 06:56am Link  |  Quote  |  Print  |  Notify Moderator
Some folks can destroy an anvil with a rubber mallet!
