RV.Net Open Roads Forum: Truck Campers: Honda 2200 on front hitch...possible overheating?
 > Honda 2200 on front hitch...possible overheating?
egarant
Mission Viejo CA
Posted: 09/17/20 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
I have a platform in which I can carry my Honda 2200 on a front hitch I had installed on my 2013 RAM. The hitch mount on this truck is much higher than most other trucks, so high that when I place the generator on it, it blocks a good portion of the front radiator.
Has anyone carried something like this that would block airflow on this truck?
Thanks all!
2021 FORD F350 dually 4x4 with 4.30 gears
2013 Eagle Cap 950
480 Watts Solar, 2K Watt Xantrex Inverter, Reonogy MPPT Charge Controller, 250 amps of lithium batteries by LifeBlue
Kayteg1
California > Nevada
Posted: 09/17/20 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
Made ca 20k miles with this set, including climbing from Dead Valley having 124F at the bottom and highest engine temp was 218F.
The 15 miles climb was at 75% of throttle even with 440 HP beast.
egarant
Mission Viejo CA
Posted: 09/17/20 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Your generator sits much lower than mine does. I will post a picture. My set up that generator will be covering ALL of that front grill area, covering the FORD emblem easily.
Buzzcut1
Norcal
Posted: 09/17/20 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Unless its right up against the body its not blocking the airflow anymore than the big flat plastic Ford Grill bars do. Unless Ram builds trucks with crappy cooling systems that is
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
jimh425
Western MT
Posted: 09/17/20 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
I carried a small amount of wood on a front hitch and my truck overheated. It was due to the fan clutch not engaging. The fix was to get a new fan clutch. So, it is definitely possible to overheat even with small blockage.
Posted: 09/17/20 11:56pm Link  |  Quote  |  Print  |  Notify Moderator
.....if your truck is in need of repair.
OP you wont have issues. My radiator, the fins are about 80% smashed flat. The kids did it over 10 years ago when they were little.
2017 Heartland Torque T29
stein4
California
Posted: 09/18/20 04:06am Link  |  Quote  |  Print  |  Notify Moderator
Put it on and see what happens
NRALIFR
Truck Camping Out West
Posted: 09/18/20 04:48am Link  |  Quote  |  Print  |  Notify Moderator
I think I would modify the carrier you have to lower its height. Look at drop pintle hitch mounts.
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450
#1Flyboy
California
Posted: 09/18/20 07:20am Link  |  Quote  |  Print  |  Notify Moderator
.... Also remember that you are driving a 7 year old vehicle ( mileage not stated ) and parts do wear out & radiators & coolers don’t get plugged up compounding the restricted air flow issue; something to consider.... I’ve had some experience in dealing with these issues...
DWeikert
York, PA
Posted: 09/18/20 07:36am Link  |  Quote  |  Print  |  Notify Moderator
I've driven this across country several times in summer heat. No problems with engine overheating. I do see a slight rise in tranny temp but not enough to worry about.
Dan
2008 Chevy D/A 2500HD ECSB
2010 Northstar 8.5 Adventurer
