RV.Net Open Roads Forum: Fifth-Wheels: Propane regulator making noise
 > Propane regulator making noise
GASMAN6674
Greenwood In
Posted: 09/21/20 07:56am Link  |  Quote  |  Print  |  Notify Moderator
The RegO 7525 series is a twin stage regulator. the change over head is the first stage (tank to 10psi) and the second regulator is the low pressure (10 psi to 11"wc) The unit carries a 10 year warranty. PS be aware the tanks shown in the picture are no longer "legal" all DOT bottle up to 40# require a OPD valve and all OPD valve have both internal POL and external QCC connections So you can continue to use POL pigtails thou I would recommend excess flow style connections. Your Unit- Your Loss
Jim & Debbie England
Do you have Gas? Propane Exceptional Energy
2015 F350 CCLB 6.2L/4:30 Vermilion Red
2020 Cougar 364BHLGone but not forgotten 2012 Ridgeline 34RLT fifth wheel/2012 V27FK V-Cross TT
reluyog
Colorado
Posted: 09/21/20 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Gasman6674, The tanks pictured DO have OPD valves, I'm using the internal threads for connection.
Damian
1983 KW W900, 3406B Cat, RTO14615, 355's
1995 Carriage by Carriage triple axle 22K
GASMAN6674
Greenwood In
Posted: 09/23/20 08:41am Link  |  Quote  |  Print  |  Notify Moderator
My apologies I needed to look at the picture closer. It sucks getting old
reluyog
Colorado
Posted: 09/23/20 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Gasman6674, No problem, and I agree with the getting older part! It seems I used to get more done everyday.
12th Man Fan
Flower Mound , Texas
Posted: 09/27/20 08:42am Link  |  Quote  |  Print  |  Notify Moderator
I replace mine with the cavagna 924. I love it. My old one was mounted on the side of the bin and I could not tell when the red flag came up without removing the tank. I could not move it due to the size of the bottle and compartment. The cavagna solved that problem.
Thanks for the replies.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
time2roll
Posted: 09/27/20 10:56am Link  |  Quote  |  Print  |  Notify Moderator
I believe you will be much happier with the operation of the Cavagna.
At least it is quiet, right? [emoticon]
675w Solar pictures back up
