RV.Net Open Roads Forum: Fifth-Wheels: water pump
 > water pump
servitrike
Posted: 09/17/20 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
looking for some wisdom.
i have a 2010 Cougar 29' 5th Wheeler. the water pump makes some terrible noises when i turn it on.
i want to check it out but i have no idea where to find it. sounds like it is on the same side of the rig as the kitchen sink, the toilet, and the fridge.
in a prior rig(an older Class A)i found it under the bed in the rear.
can somebody point me in the right direction as to where it mite be located?
MitchF150
Puyallup, WA
Posted: 09/17/20 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
I'd think that if it makes so much noise, you should be able to at least pin point the 'general' location of it??
On my old Prowler, it was under the kitchen sink cabinet. On my new Rockwood, it's all the way in the back in the bathroom, inside a lower cabinet and about as far away from the fresh water tank as it can be!
It's pretty quiet overall, but since the bedroom is up front, you can hardly hear it in the middle of night if used..
Good luck! Mitch
agesilaus
North Florida
Posted: 09/17/20 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
Its under the kitchen sink in our Arctic Fox. I brought a spare pump along to use to pump water from water carboys into the drinking water tank. Of course the installed pump died one afternoon but I was ready, an easy install I did change the orientation of the pump to make it easier to work on. I had to cut the rubber feet away from the old pump since the screw heads were too corroded to unscrew. I used corrosion resistant screws on the new pump.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
servitrike
Posted: 09/17/20 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
my under sink cabinet is a big empty space.
but i will look again.
schlep1967
Harrisburg, PA
Posted: 09/18/20 05:00am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like the pump is working so you really don't need to find it. Go to where the noise is. Run some water to make the pump run. Reach into wherever the noise is and start grabbing water lines. One of them is likely vibrating against something. When you grab the right one the noise will stop. You can put a rag in between the pipe and whatever it is vibrating against temporarily. Better fix would be a piece of pipe insulation.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
dmck413
Fluvanna Va
Posted: 09/18/20 06:08am Link  |  Quote  |  Print  |  Notify Moderator
Mine is behind the basement wall
valhalla360
No paticular place.
Posted: 09/18/20 06:22am Link  |  Quote  |  Print  |  Notify Moderator
I've seen them in all kinds of places.
Have someone turn it on and follow the sound. That should put you within a couple feet of the location...then just look around and follow the hoses.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
gkainz
Arvada, CO, USA
Posted: 09/18/20 07:57am Link  |  Quote  |  Print  |  Notify Moderator
mine is also behind the basement wall in the front storage compartment, curb side. There's a small black plastic cover hanging over a maybe 6" hole to access the winterizing hose and valve. The wall comes down with a few screws for easy access to the pump and plumbing.
I quieted mine down significantly with "pool noodle" type insulation tubes around all the hoses within reach that might vibrate against anything, as well as remounting the pump on a piece of closed cell foam (garden knee pad cut to fit).
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
Veebyes
Posted: 09/18/20 09:41am Link  |  Quote  |  Print  |  Notify Moderator
Follow the pipes. The pump should not be far from the FW tank. The pump is something that can be expected to fail at some point therefore should be in a reasonably accessible location.
2007 Alpenlite 34RLR
ksg5000
Oregon
Posted: 09/18/20 10:31am Link  |  Quote  |  Print  |  Notify Moderator
As others have said .. follow the noise. And BTW - water pumps tend to be very noisy and there are plenty of threads (use forum search feature) which provide various methods to make them less of a problem.
Kevin
 > water pump
