RV.Net Open Roads Forum: Tech Issues: Portable Wind Turbine as a power supplement?
 > Portable Wind Turbine as a power supplement?
jkwilson
Indiana
Posted: 09/18/20 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
Running a wind turbine while towing will cost you more energy from your truck than it will produce. It will be at best the same as running a generator. Simple laws of physics.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
DrewE
Vermont
Posted: 09/18/20 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
Using the engine alternator to charge the batteries on the road will definitely be more efficient overall than a wind turbine. The power for the wind turbine comes from the vehicle engine, but you have all the losses of going through the drivetrain combined with the extra parasitic drag of the turbine (something it's most likely not especially designed to minimize, since in most cases it doesn't matter that the wind is impeded more than necessary). Directly connecting your generator (i.e. alternator) to the engine is more efficient.
An extra foot or so of height can make a significant difference on overhead clearances in some areas of the country, such as New England. In other areas, low clearances are far less common, perhaps excepting tree branches. If the extra height puts you above the basic legal maximum of 13'6", you'll need special permits for every trip and be very much constrained on where you can fit.
Working to minimize power usage is just as valid as working to maximize power production.
KD4UPL
Swoope, VA
Posted: 09/18/20 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
If you add the drag of a wind turbine to your RV then the engine needs to work harder to overcome the drag. You will be wasting energy with the "mobile while driving" set up. That's just a physics problem.
As for stationary use, small wind turbines are typically rated for maximum output at 28 mph wind speed. I don't know about you but camping with a steady 28 mph wind does not sound like fun at all to me.
The energy available in the wind is based on the cube of the wind speed so if you cut the wind speed in half you cut the potential energy by a factor of eight. So, let's reduce that wind speed to a more reasonable 14 mph. A typical small wind turbine like the Air-X is rated at 400 watts at 28 mph. With a 14 mph wind speed it is now only making 50 watts. No, you can't use a gear box to speed it up, again, physics is against you. There just isn't enough energy in slow wind to make it worth trying to recover it.
profdant139
Posted: 09/18/20 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
It was a fun idea, though. Keep thinking outside the box!!
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
BarneyS
S.E. Lower Michigan
Posted: 09/18/20 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Moved to Tech Issues forum from DIY.
free radical
Canada
Posted: 09/18/20 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
ToastHater wrote:
First post here, so I apologize if this is the wrong area.
I'm doing research and planning out a custom RV (cargo van/step van/box truck conversion...undecided), and looking to be as green and self sufficient as possible. Moving to a full time RV/Boondocking lifestyle.
I've done a lot of research into solar, and believe I have a solid plan. From what I understand, it's always better to plan for more than what you think you'll use when it comes to power/water. So I wanted to look into supplementing a semi-standard "rooftop solar setup." Portable solar panels are an easy option, and a diesel generator is almost a must (from what I understand).
I wanted to ask if anyone has experience with a portable wind turbine as a supplement to solar. I totally understand that, similar to solar, it's dependant on the available wind in the area.
I also had a kinda crazy idea, that I wanted to share, and see if it's valid.
Doing some research on turbines. Their running speed is generally between 12 and 30 mph, with a rated speed of 100 - 120 mpg (usually shutting off around 50 - 60 mpg).
I wanted to see if you could add an inline speed reducer gearbox, between the blades of the turbine, and the generator itself. So that its running speed can be increased to between 50 - 70 mph. Thus enabling you to mount a horizontal shaft turbine through the roof, to generate power while driving at freeway speeds.
There are quite a few horizontal shaft rotors that are fairly low profile, and be great for this kind of application. I'm just not certain it would work as I'm intending.
(I understand a lot of concepts well, but don't have the practical knowledge. Some DIY House Repair as well as metal/wood fabrication experience.)
Take a look at these vertical chargers
Specs beat any horizontal windcharger of same size
https://www.windside.com/
Instead of roof how about mounting it on a back bumper and make it expandable above roof when parked.
Or on front bumper and it would catch plenty air when driving
Features include:
2-5 m/s cut-in wind speed
Up to 60 m/s max wind speed
50+ year lifespan
5-yr maintenance-free (optional)
Soundless Operation
No vibration
Graceful rotation
Primary function is to charge 12/24/48VDC battery banks which power DC loads including DC/AC inverters for 110/230VAC output.
free radical
Canada
Posted: 09/18/20 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
I guess OP has something like this in mind
https://en.wikipedia.org/wiki/Ram_air_turbine
Not very practical to put on RV imo
Bert the Welder
Van. Island
Posted: 09/20/20 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Another potential issue would be the strain on the mounting system/fasteners on the roof.
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
jkwilson
Indiana
Posted: 09/20/20 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
I actually worked on two systems mentioned in that article, though on one I only worked on a shipboard version so no RAT.
Even a RAT consumes more power from the vehicle than it produces.
ToastHater
My House?
Posted: 09/20/20 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for the advice and information. It was kind of a wild idea, and I had no idea about the energy potential of the alternator (or dual alternators).
Yeah. I used the wrong terminology in the OP. This is what I had in mind. Posted up on the roof.
