RV.Net Open Roads Forum: Tech Issues: Portable Wind Turbine as a power supplement?
 > Portable Wind Turbine as a power supplement?
Dtank
Posted: 09/23/20 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
profdant139 wrote:
It was a fun idea, though. Keep thinking outside the box!!
.......and another fun idea.......
maybe change your ID to "Rube Goldberg, Jr." ??
[emoticon]
rlw999
Washington State
Posted: 09/23/20 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
I wanted to see if you could add an inline speed reducer gearbox, between the blades of the turbine, and the generator itself. So that its running speed can be increased to between 50 - 70 mph. Thus enabling you to mount a horizontal shaft turbine through the roof, to generate power while driving at freeway speeds.
There's really no reason to do that, it's just a very lossy way to capture power, you're better off tapping your alternator (possibly adding a second/bigger alternator). By the time the energy reaches your wind powered generator, the power has gone from the engine to the transmission to the wheels to the wind and finally to your turbine and generator. You're losing energy at each step so you're better off just tapping it off the engine directly.
Then if you still want a wind turbine, you can optimize it for ambient wind speed, which is going to be a lot less than 70mph unless you camp in hurricanes a lot.
ToastHater
My House?
Posted: 09/24/20 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Hey, I'll take it. lol
I love thinking outside the box. Especially in these situations. There are so many great (and terrible) ideas in the "#vanlife" community. This idea may have been a bust, but I learned something from it.
Again, I do appreciate all the advice given.
mikestock
Vestavia Hills, AL, USA
Posted: 09/27/20 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
If you can work out a way to capture only the regenerative energy available when you are purposely slowing down or going down hill, you may have something. You certainly won't gain anything by using the engines power (fuel) to generate electrical power over and above that required to run the vehicle's essential functions.
cyrus799
US
Posted: 09/19/21 02:26am Link  |  Quote  |  Print  |  Notify Moderator
This ECO-WORTHY solar power kit is amazing because it combines the power generation capabilities of a wind turbine with the sun-catching skills of a solar panel. With such a wide range of operations, this kit can offer the user with a virtually constant source of electricity. It's ideal for traveling to places that aren't as windy but receive a lot of sun, or vice versa.
Posted: 09/19/21 07:44am Link  |  Quote  |  Print  |  Notify Moderator
One of the differences between wind and solar is this.
I have heard someone say "Solar won't work because the sun does not always shine"
The sun has been shining for I have no idea how many thousands of years, and it's expected to shine for millions more. no breaks, no interruptions, constantly shining, (The speaker just turned his face away from the light of truth and thus tells lies)
WIND. on the other hand. does not always blow.
So though I can count on an average of 10 or more hours of sun daily.
Wind... Not so. (The rest of the time the sun shines on the backside of the planet, back side from where I'm standing that is)
deltabravo
Spokane, WA
Posted: 09/19/21 08:19am Link  |  Quote  |  Print  |  Notify Moderator
ToastHater wrote:
A second alternator makes a ton more sense as an easy solution.
Ditto.
My truck has a factory second alternator. I upgraded the charge line between the truck and camper with 4AWG cable. Here's how I did it
Then this year I added a Victron DC to DC Charger. Here's a video on that project
wolfe10
Posted: 09/19/21 10:08am Link  |  Quote  |  Print  |  Notify Moderator
A little short on FACTS. Would like to see a wind speed vs output.
The 400 watts they advertise is produced at 13 MPS= 29 MPH. WOW.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
ktmrfs
Portland, Oregon
Posted: 09/19/21 10:30am Link  |  Quote  |  Print  |  Notify Moderator
e.g. your trying to make a perpetual motion machine. Can't defy the laws of physics, the energy you get from the windmill on top of the trailer etc. will be less than the extra energy required to drive down the road.
If what you want is to charge the battery(s) while you are driving the alternator will do that, and if needed a second alternator and alternators are very efficient and will likely have less energy loss that a wind turbine on the roof would.
BTW I can easily charge a band of four GC-2 batteries from my single alternator when driving. A days drive 6-8 hours will bring them from about 50% SOC to 80%+ pretty easily.
2011 Keystone Outback 295RE
mobeewan
Hampton, Va
Posted: 09/19/21 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
I was thinking about building something like a ram air turbine using a high output alternator turned by a fan blade with everything mounted inside of a ducted shroud. I could either mount it on my truck rack or mount it on a bracket installed on the trailer tongue. Mounting it on the trailer tongue may create the least amount of drag since the front wall of the trailer creates a massive amount of drag anyway. It would be used to charge a battery bank while towing.
This would however depend on how big the fan has to be and how many rpms it could produce at highway speeds.
