RV.Net Open Roads Forum: Class A Motorhomes: Kitchen and Bathroom fans
 > Kitchen and Bathroom fans
Branson N Tucson
Tn
Posted: 09/18/20 04:47am Link  |  Quote  |  Print  |  Notify Moderator
Have a 2003 Fleetwood Providence that has the Max Air fans in the ceiling fans located in bath room and kitchen ceiling area.(sure older model no remote) Both are not working. They both have fuses located on them. Both fuses are good. There must be a main fuse that supplies power to both. Tried checking the fuses in both areas by the brake peddle and in bedroom area. Boy alot of fuses to check. Can anyone help narrow the search area down for the bad fuse.
Thanks for the help.
rk911
DuPage County
Posted: 09/18/20 08:21am Link  |  Quote  |  Print  |  Notify Moderator
check for tripped GFIC outlets. on a previous MH we found we had one in an exterior storage bay so look carefully.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
jdc1
Rescue, Ca
Posted: 09/18/20 08:42am Link  |  Quote  |  Print  |  Notify Moderator
The fans are 12v, so it's not going to be a GFCI outlet problem. Do you have a light near the fan? Is that light on a wall switch? The previous owner may have used the light power to power the fan also. You just have to work backwards, making sure all the wire nuts are tight. I always tug on both wires, to make sure everything is tight.
MountainAir05
New Mexico
Posted: 09/18/20 09:33am Link  |  Quote  |  Print  |  Notify Moderator
Along with what Jdc1 state check for your Volts on the wire nuts or plug.
RLS7201
Posted: 09/18/20 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Close to your batteries is a black box (battery control center). There is a circuit board, fuses and relays inside. Maybe one of those fuses control your fans. There is a wiring diagram on the inside of the cover.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
rk911
DuPage County
Posted: 09/18/20 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
well, duhhhh. where was my brain? sorry
dougrainer
Carrolton, Texas
Posted: 09/18/20 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Are the lids power up and down? If non powered, then check the metal pin switch on TOP the mechanism accessed from on top with the lid open. THAT Pin switch is the GROUND supply for the fan motor. usually you just have to use a 7/16 open end wrench to tighten that pin switch to get a good contac for that ground wire. Doug
Wherever I happen to park
Posted: 09/18/20 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Knee jerk response. The Maxx Air's are 12 volt fans. NO GFCI involved.
Home is where I park it.
Tim Nowicki
Alden NY
Posted: 09/18/20 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Had the same problem with my fans on my fifth wheel. Turned out to be not a problem at all. Each fan has a wall switch. Looks like a thermostat slider switch. Slider is an on and off switch that operate the fans.
cavie
Posted: 09/18/20 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
deleted.
